Can someone explain early 944 tachometer wiring to me?
My 944 apparently has a storied history and has had the 0,5 green wire coming tachometer pin 6 cut. If i reconnect it to where it was cut off, the car won't start, instead sputtering out and dying.
My question is - where can I jump this wire to get the tach working again? Does the other end of this connector lead to the ignition coil, or back to the DME? The wiring diagram is not totally clear. Any insight would be very valuable.
Old 10-29-2009, 12:49 PM
Sorry, I meant the green 0,5 wire coming from the tachometer has been cut.
Old 10-29-2009, 12:51 PM
Toofah King Bad
Rasta Monsta's Avatar
If handy, I would try a different tach. . .it may have a internal short that is killing the ignition.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-29-2009, 01:27 PM
