Still having starter problems
I installed a used starter in my 78 924 that had set for 8 years and it wouldn't turn the engine. I ordered a new starter, installed it and it still won't turn. I have removed the plugs, put oil in the cylinders, and can turn the engine by hand using a socket wrench on the crank. The engine does fill tight, but with a brand new battery, and a new starter, it should do more than just barely turn the engine, and then stop. According to the manual there are 2 resisters in line with the wire from the key switch to the starter and it mentions something about starter boost. I hooked a jumper cable from the negative on the battery to the frame to insure a good ground. Am I missing something here.
1978 924 1/2 way there
Pictures Coming
Old 08-21-2007, 05:11 PM
Ground the battery to the engine not the frame. I replaced my battery cables and fixed a problem with my starter. It is possible to get a bad rebuilt starter. Easy to take it off and have it tested. Easy to jump the starter solenoid and make sure the starter turns. Good luck
Bradley Atherton
1988 Porsche 924S
Purchased Oct 2006
modifications: rechipped (?)
Red/Black interior
Old 08-21-2007, 05:33 PM
