No start 86 951-- injectors not firing
I just completed an intake refresh/venturi delete on my 951.
I have excellent fuel pressure, 3 bar, tested with old DME relay, new DME relay and jumper.
I have spark, tested with timing light.
The injectors are not spraying any fuel. They were cleaned/flowed by withhunter.
All the injectors pass click test with a 9V battery. I can even put in the jumper, and get each injector to spray fuel into a bottle by hitting it with the 9v battery.
I verified my injector harness is not broken/cracked with DME pin 14/15 and KLR pin 6.
My S&R sensors both work, I replaced one that had a messed up connector with the matching one from the 924S in the process of troubleshooting the no start.
I hooked up my multimeter to one of the injector clips, when I turn the key to "ON" I get 2V. When I crank the car I still get 2V at the clip, no change.
I pulled the DME and opened it up, nothing looks burned, scorched or funny....
I dont know what else could be wrong....
2000 Audi A6 4.2 - Current DD
1991 944 S2 - sold
1986 951 - departed
1988 924S - departed
1980 928S - sold
Old 10-07-2007, 07:02 PM
Do you have a noid light? This will tell you if the DME is supplying the pulse to the injectors. I re-read what you wrote. the 2 volt reading, is that the voltage between the two leads to the injector or reading to a ground point?
Mark
'83 Porsche 944 NA
'90 Porsche 944 S2
Old 10-07-2007, 07:40 PM
I do not have a noid light. Is that something that I can pick up at a Pep Boys??
The 2v I measured is between the two leads to the injector
1991 944 S2 - sold
1986 951 - departed
1980 928S - sold
Old 10-07-2007, 07:50 PM
