Obin Robinson's Avatar
rained last night: 944 turn signal fuse keeps popping
the short of it:
we had a massive rain storm here last night. today i had my car re-inspected and it kept popping turn signal fuses.
the obvious:
something is shorted out
the question:
where should i look first. the interior is dry, but the rear lights have some water in them. of course i should dry them out first. is that where 100% of the problem is or is there another nook and cranny i should check.
thanks!
obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 08-22-2007, 03:58 PM
livewirevoodoo's Avatar
The rear lights are a good place to start. Infact, start with the rear hatch drain tubes located above the pin catch. Make sure the tubes are connected to the drain holes (and clear of debris).
One thing I have done (from a tip on this board) is to drill the smalled hole pobbile in the lower middle tail light for added drainage (atleast that was the light that didnt drain water for me).
Check the front & side turn signals as well. I know for me the housing for the side signals would take on a bit of water now and again.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 08-22-2007, 04:41 PM
adrian1's Avatar
yep its probably (97% ) the water in the rear taillights that is causing it. Check also under the hood the the water is draining out from where the fuse box is, Whenever it rained i had a little fish tank in there until i cleaned out the drainage holes next to the fender...lol
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 08-22-2007, 11:47 PM
cold starter
JustinL's Avatar
You could buy some non conductive blinker fluid...
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 08-23-2007, 08:01 AM
Not Special
On the earlies our fuses are inside the cabin, not under the hood, so I'd start with the water in back.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 08-23-2007, 08:58 AM
adrian1's Avatar
oh right, forgot its the early car......
1981 Corvette 4spd
Old 08-23-2007, 12:31 PM
drained the water out...
fuses still popping intermittently
i also noticed that the relays are getting hot as well. short somewhere?
thanks!
obin
Old 08-24-2007, 02:18 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
maybe the fusebox is getting wet - hose down the fusebox with WD-40? (wow, an actual VALID application for the stuff)
nate
1988 944... and a bunch of other cars
Old 08-24-2007, 02:55 PM
fuse box is TOTALLY dry. i'm thinking that the only thing left is to go through the entire electrical system until i find the short
obin
Old 08-24-2007, 08:23 PM
the fuse is popping if i have the key in the ignition and sitting in the accessories position. without the flashers on this fuse is still popping
can it be a bad relay?
obin
Old 08-26-2007, 10:59 AM
