Help with removing wheel locks............
I need to remove my rear wheels and dont have a key for the locks I think they are the factroy ones. Any sugestions??
Old 08-28-2007, 02:35 PM
Custom User Title
Dave L's Avatar
lock smith should be able to pick it
Old 08-28-2007, 03:15 PM
Non Compos Mentis
3/4" or 19mm circle cutter will drill off the lock and leave the threads intact if done carefully.
Old 08-28-2007, 03:21 PM
I'm pretty sure the lug nut that's under the lock is hollow. So, you should be able to drill out the lock without damaging the lug. That is, if you that the same type of wheel locks that I have where it's a locking cover with a fairly normal lug nut underneath.
Vern
Old 08-28-2007, 04:14 PM
flash968's Avatar
go to the dealer - they can probably get you a key - it will NOT be free, but you won't damage your wheels
Old 08-28-2007, 04:56 PM
