adrian1's Avatar
Porsche Crest Question about Changing header gasket
On my 1986 951 My exhaust header gasket nearest to the firewall is messed up. I will be changing them very soon and was wondering when unbolting it from the cylinder head will it be loose enough to slide the new gasket on the studs into place or will i have to unbolt the entire manifold?
Thanks , Adrian
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 08-28-2007, 04:30 PM
Send a message via AIM to bholmes
Depends on the type of gasket, if it is the type that is "u" shaped where the bolt goes, you certainly can. If it's the type that just had a hole for the stud, then you'll need to remove the header. I have removed the header completely several times and it's not to bad.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 08-28-2007, 07:46 PM
That Guy
Techno Duck's Avatar
The gaskets have holes for each of the studs. Something you might try and do is remove the studs by double nutting and slide the gasket in. Not sure if you will be able to slide them between the header or not. Studs are a love or hate kinda thing, they either turn right out or are a pain in the butt to remove.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-28-2007, 08:03 PM
adrian1's Avatar
If i do have to take it off can i reuse the old gasket from the other end?Or do i haved to buy a new one?
1981 Corvette 4spd
Old 08-28-2007, 10:17 PM
Buy new ones!! It's not worth the savings.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 08-29-2007, 06:08 PM
fast924S's Avatar
Send a message via AIM to fast924S
I agree with bholmes, WHy not replace all 4 while you are in there, they arent that expensive. Just make sure you use alot of penitrating oil
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 08-30-2007, 07:05 PM
adrian1's Avatar
I know what you mean about the 4 cause i already ordered all of those. I was just thinking that i can change them without taking off the manifold but i remembered all the piping for the turbo will make it stiff, so last night i had to order those 2 seals. They are round am i correct?
1981 Corvette 4spd
Old 08-30-2007, 07:20 PM
