-   -   How to disable factory alarm? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/366224-how-disable-factory-alarm.html)
Porsche-O-Phile 09-09-2007 08:09 PM
Trying to avoid having to trace wiring diagrams here:
I'm preparing a "spare" '85.5 n/a 944 for sale and chased down an annoying battery-drain problem to the factory alarm. Used to be whenever the car sat for more than a week, the battery would completely drain out. I removed the factory alarm box behind the DME, which remedied the problem, but when I went to start the car, it wouldn't start without the alarm box re-installed (which I'm sure will bring back the battery drain problem).
Anyone know how I can eliminate the factory alarm box (ridding myself of the battery drain problem) and not have it kill the DME and prevent the car from starting? Is there something I should be jumpering someplace or whatever?
Note that the factory alarm switch is in the "off" position - I never got a key for it.
JivenJim 09-09-2007 08:34 PM
http://www.clarks-garage.com/ search "elect-23"
I also wish I had pre 75 911 swaped engine :+)
Porsche-O-Phile 09-10-2007 06:19 AM
Ahh, perfect. I hope the procedure works with the module completely removed, but I'll try it for starters. Thanks.
88BlueTSiQuest 09-10-2007 02:37 PM
It does. I removed my alarm and simply cut and connected the wires that Clark's says to jumper.
