Dog-faced pony soldier
Porsche-O-Phile's Avatar
How to disable factory alarm?
Trying to avoid having to trace wiring diagrams here:
I'm preparing a "spare" '85.5 n/a 944 for sale and chased down an annoying battery-drain problem to the factory alarm. Used to be whenever the car sat for more than a week, the battery would completely drain out. I removed the factory alarm box behind the DME, which remedied the problem, but when I went to start the car, it wouldn't start without the alarm box re-installed (which I'm sure will bring back the battery drain problem).
Anyone know how I can eliminate the factory alarm box (ridding myself of the battery drain problem) and not have it kill the DME and prevent the car from starting? Is there something I should be jumpering someplace or whatever?
Note that the factory alarm switch is in the "off" position - I never got a key for it.
Black Cars Matter
Old 09-09-2007, 08:09 PM
http://www.clarks-garage.com/ search "elect-23"
I also wish I had pre 75 911 swaped engine :+)
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 09-09-2007, 08:34 PM
Ahh, perfect. I hope the procedure works with the module completely removed, but I'll try it for starters. Thanks.
Black Cars Matter
Old 09-10-2007, 06:19 AM
It does. I removed my alarm and simply cut and connected the wires that Clark's says to jumper.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 09-10-2007, 02:37 PM
