How to take cam out?
hi, i already have the cam tower(and lifters) out of the car. I tried to just jently pull the cam out but it wouldn't come. how do i take it out properly? do i have to mess with the cap on the end? I know its probably easy but i didn't want to mess anything up.
thanks
Old 09-09-2007, 11:06 AM
Used & Abused
Yes you have to mess with the cap on the end. Unbolt the cap and the cam should slide out the rear or the tower. You can tap on the front of the cam with a rubber mallet to get it started but once the front is through the hole you should only wiggle and turn the cam the rest of the way.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 09-09-2007, 04:53 PM
oh ok so you have to take the cam gear off?
Old 09-09-2007, 05:57 PM
Used & Abused
yes
Old 09-09-2007, 08:03 PM
meister member
speedracing944's Avatar
After you take apart the cam gear housing you should be able to slide the cam out easily. Make sure to do a complete cam tower reseal with new seals while you are reassembling.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-11-2007, 03:58 AM
Back from Beyond
^+1
No need to take the cam gear off - the cam should slide out the front, rotate it gently as you go.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-11-2007, 12:22 PM
meister member
IIRC you need to remove the cam gear to get to the 3 bolts holding the rear cam housing to the tower.
check out www.clarks-garage.com
Speedy
Old 09-11-2007, 03:57 PM
Zero10's Avatar
Send a message via ICQ to Zero10
No way to take the front cover off with the cam gear on AFAIK, plus you will want to change the front cam seal too.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-13-2007, 04:09 AM
