exitwound's Avatar
Replaced Dash, Dome/Trunk Light Not Working
Door chime works but the dome light will not work (in any position) nor will the trunk light. What may I have done? Is this related to the glove box light in any way? During the glove box removal (forgetting to disconnect the battery) we blew the glove box light inadvertantly.
-Patrick
Black 1986 944
Old 09-28-2007, 01:35 PM
Aslet's Avatar
Did you blow a fuse too? I know I have blown a few fuses messing around without disconnecting the battery :-P
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 09-28-2007, 02:14 PM
livewirevoodoo's Avatar
Glove box light should not matter. Check your rear hatch struts wiring connection (for the defroster grid)... a bad ground on those cold cause the dome light to malfunction while a door is open, but in that case the dome light switch should still work when switched to the "always on" position. Check bulb, fuse and wiring.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 09-28-2007, 07:07 PM
