hey need help quickly to answer a wheel offset question!!!
hey guys, im about to buy a new set of wheels for my 1990s2
just want to make sure these will fit. i knwo the rear offest will be cutting it close, but i figure since im lowering my car, i will give it another degree or so of negative camber and roll the fenders and i should be ok. anyways here are the specs on the wheels: Bolt Pattern: 5x130 Size: 18x8 front/ 18x10 REAR Offset: +48mm front/ +40MM REAR thanks in advance!! |
anyone!?? please :)
The rears wont fit. The 45mm offset will be good for a early offset car..on a late offset they will stick out way to far. You need something closer to a 60 to 65mm rear offset for it to fit right. I suppose you could always put on a early offset rear hub..or seriously flare the fenders.
Most 18x10's are a 65mm offset for late offset cars, they sit basically flush with the rear fender. |
| All times are GMT -8. The time now is 03:20 AM. |
