jbrill's Avatar
Send a message via AIM to jbrill Send a message via MSN to jbrill Send a message via Yahoo to jbrill
hey need help quickly to answer a wheel offset question!!!
hey guys, im about to buy a new set of wheels for my 1990s2
just want to make sure these will fit.
i knwo the rear offest will be cutting it close, but i figure since im lowering my car, i will give it another degree or so of negative camber and roll the fenders and i should be ok. anyways here are the specs on the wheels:
Bolt Pattern: 5x130
Size: 18x8 front/ 18x10 REAR
Offset: +48mm front/ +40MM REAR
thanks in advance!!
Jordan
1990 944s2 Eurospec With some mods
Old 10-08-2007, 11:35 PM
jbrill's Avatar
anyone!?? please
Jordan
Old 10-09-2007, 08:54 AM
That Guy
Techno Duck's Avatar
The rears wont fit. The 45mm offset will be good for a early offset car..on a late offset they will stick out way to far. You need something closer to a 60 to 65mm rear offset for it to fit right. I suppose you could always put on a early offset rear hub..or seriously flare the fenders.
Most 18x10's are a 65mm offset for late offset cars, they sit basically flush with the rear fender.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-09-2007, 05:58 PM
