No wipers,Blower,Windows,Mirrors. HELP!
First off,...What a GREAT site!
I posted this question last night in the Porsche 944 Turbo and turbo S forum. Probably better asked in this forum.
I have a 86 944T that has sat for a few months. No mods,84,000 miles,starts and runs fine. I started the car yesterday (the first time in 3 months) and the wipers,blower fan,electric windows,electric mirrors ALL don't work. The window and wipers worked for about 2 minutes after I started the car (don't know about the blower and mirrors yet) All fuses are good. I figured it MUST be a common ground issue. I went searching and came up on the two ground points (mpII & mpIII ?) on the inside firewall just left of the steering column. I cleaned and sealed ( Worth contact SW and dielectric grease) both of them. Still no luck. As I went to start the car to move it, the wipers mover about 2 inches and the window worked for a few minutes and then went dead again. The blower and mirrors never "came back to life". As the car sits now, ALL the above mentioned systems are dead!
UMmm,.....HELP!!!!!!!!!!
Thanks in advance, Mike
BTW; I spent 2.5 hours searching last night and didn't come up with anything like this problem. I DID come up with a TON of cool information though! Thanks guys!
Old 10-19-2007, 06:29 PM
Redline Racer
HondaDustR's Avatar
I guess you could use a voltmeter to see if consisten power is getting to them, or if it is an internal failiure. Also, are your fuses the newer spade type or the old bullet type? If it's the older ones, check that the fuses are making good contact in the fuse block, as I had one that was pretty flakey if touched, and had to have the contacts "scrubbed in" so to speak.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-19-2007, 06:36 PM
Paul_Heery's Avatar
Mike,
Are you in Bethel?
If you've already checked the ground points, I'd go through and check all of the connections in the power box.
Paul
Old 10-20-2007, 04:45 AM
Hey Paul. Long time no see. Are you off the VW's and on to Porsches? If you want to polish your electrical contact cleaning skills,.....I got the car for you! This thing is killin me!
See ya, Mike
Old 10-21-2007, 09:55 PM
Banned
I posted a suggestion in your other thread.
Old 10-22-2007, 07:35 AM
I have this problem with my S2 and its the ignition switch at fault .If i turn the key a couple of mm back once the engine is running they kick in to life
mark
Old 10-29-2007, 01:58 PM
