father and son
How do you reinstall the 1st position fan relay for a 844 944?
I removed the relay to test it while troubleshooting my fan problem. It was a bear to remove but there is no way I can figure out how to reinstall it. Is there a trick or am I just missing something?
Old 10-20-2007, 03:23 PM
Politically Incorrect
onZedge's Avatar
Just push it in.
Edek
'87 924S
'91 535i
Old 10-20-2007, 03:36 PM
onZedge's Avatar
OK, really...
Make sure you have the pins oriented correctly. Use electrical contact cleaner/lubricant like CRC QD. That relay is on the top row of the relay/fusebox. The top row of relay sockets are snapped in to the relay/fusebox "motherboard" and can flex quite a bit.
Edek
'87 924S
'91 535i
Old 10-20-2007, 03:43 PM
