Eldorado's Avatar
bearings on these beasts
I know the rear bearings well... most of you will remember that pic I posted - due to this being a G - rated board, I wont post the pic of my bearing's horrible death again..
now the fronts on the other hand... what's the deal with those? I haven't had the time to rip the wheel off yet and take a look, but what am I looking at here? clarks, as far as I know, doesn't mention the front bearings at all... just the rears..
is it a hub assembly? or are they individual pieces like the rears?
remember we're talking about an early car here, which is different than the laters.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-17-2007, 10:22 PM
Eldorado's Avatar
found the directions..
anyone have a parts list I'd need to do a front wheel bearing job?
Kyle
Old 10-17-2007, 10:26 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
EZ work....same style as rears...
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 10-18-2007, 03:16 AM
That Guy
Techno Duck's Avatar
Get the proper bearings for the early offset hubs and new inner seals.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-18-2007, 04:09 AM
Very easy to do, after you remove the hub (by loosening the little allen bolt) you just pop out the old bearings and put in the new (greased) ones.
The bearing race is the most difficult to get out as it is pressed in. I used a plastic sprinkler pipe, caught the edge of the race and tapped it out - took about 5 minutes.
Vern
Old 10-18-2007, 10:39 AM
Back from Beyond
Throw your new races in the freezer a couple of hours before install. That'll help. If you really want to get technical you can heat the hubs in the oven, too...
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 10-18-2007, 02:41 PM
Eldorado's Avatar
great ideas guys..
anyone have a parts list? only list available on clarks is for the rears.. and I dont have PET available to me right now..
Kyle
Old 10-18-2007, 08:44 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
I am trying to remove rear steel hubs and I can't seem to get them out of the trailing arm. I've been prying and pounding and they just won't budge. Anyone have any advice?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 10-22-2007, 08:51 AM
Eldorado's Avatar
mine just pulled out. Are you sure you're not missing a bolt somewhere?
Kyle
Old 10-22-2007, 09:37 AM
Back from Beyond
I'm assuming you've disconnected the CV axle? I place a block of wood on the stub axle and pound it inboard - that should break everything free and you can pull the hub off. It shouldn't take a lot of force.
All others GONE!
Old 10-22-2007, 09:38 AM
TNT25169's Avatar
The trailing arms are off the car and everything is disconnected but it won't pull out. I remove the rotor and I pulled really hard on the hub and it won't move. Am I supposed to remove something ni the back where the cv joints connect? Such as a bearing cup? Everything that bolts on is disconnected as far as I can tell. I will post pictures tonight.
www.apartabove.com
Old 10-22-2007, 01:11 PM
Back from Beyond
At the risk of sounding like someone's grandma, you did remove the huge nut holding the hub to the stub axle, didn't you? I'm stumped. Maybe the pics will help.
BTW, Kyle, did you get your parts together? I found the only part of the job that required a little finesse was learning how to adjust the bearings. And the inner hex bolts on the clamping nuts can strip out easily. If you liked making mud pies as a kid then bearing grease is the thing for you.
All others GONE!
Old 10-22-2007, 09:37 PM
Eldorado's Avatar
i've got the parts i need, yea.. not as many pieces as the rears..
what exactly about the bearings need to be 'adjusted'?
Kyle
Old 10-22-2007, 09:51 PM
Back from Beyond
Haynes describes the process as spinning the hub by hand and tightening the clamping nut to seat the bearings properly. They're adjusted when you can just move the thrust washer with the blade of a screwdriver, unsupported. I've seen mechanics do this just by hand-tightening the clamping nut and I know of one source that says 'finger tight plus 1/4 turn' to adjust. Too tight and the bearings wear fast. Too loose and the car ends up with excess bump steer and a wandering front end. Used to drive me nuts. When it's done right (and regularly) you'll notice a definite improvement in the way the car handles. I'm sure there are guys here with much more knowledge about this than I have, though. There's some interesting stuff on the net about bearing preload too.
All others GONE!
Old 10-22-2007, 10:14 PM
Eldorado's Avatar
I've done the rears so it's nothing new, but the fronts are a little different..
so I figure i'll order that stuff.. need to order some oil filters and an air filter as well anyway.. looks like everything is going to come out to about 200 bucks.. bearings on 3 corners (did the 4th last year).. hard to ignore that sweet US dollar
and it'll be nice to get that "wubwubwubwubwubwub" sound out of the right side of the car while driving :P
Kyle
Old 10-22-2007, 10:26 PM
TNT25169's Avatar
Here are a few pictures. I would think the hub would just pull out but that doesn't seem to be the case.
www.apartabove.com
Old 10-23-2007, 07:11 AM
Back from Beyond
Hmmm. I don't know a lot about the later cars but I can't see a reason that wouldn't come off. Maybe try tapping it in instead of out - it may be cockeyed and binding. Can you snap a pic of the back? You got me... (not saying much, really...)
All others GONE!
Old 10-23-2007, 04:12 PM
Politically Incorrect
onZedge's Avatar
What have I got myself into...
Arnnworx says to use a big slide hammer. FSM says to hammer it out from the backside with a drift.
I'm doing those rear aluminum trailing arm bearings this weekend. I plan on not removing the arms from the car. I have the Arnnworx bearing puller, but have to rent a bearing separator and now, a big slide hammer as well. Thanks for the heads up.
Edek
'87 924S
'91 535i
Old 10-23-2007, 04:39 PM
Back from Beyond
So on the later cars the hub is pressed into the control arm? You poor sod.
All others GONE!
Old 10-25-2007, 08:12 AM
The hub and internal (female) spline is one piece. It rides on the wheel bearing's 2-piece inner race.
Once the hub breaks free from half of split inner race, it will take with it the other half of the inner race.
A slide hammer from the front or a hammer and drift on the backside will get it off.
There is a lot of resistance because the ball bearings are still riding on the inner race groove.
For the hub to come off, the ball bearings have to jump off the inner race groove.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-25-2007, 11:57 AM
