Help with piston compressions by looking at them?
Hey All,
I have several (3) 944 engines that I know are all from 86-87 944s. All are stamped M44/07 or 08(indicating an auto trans) but I'm wondering is there a way to distinguish pistons that have a CR of 9.5:1 in '86 from those that have a CR of 10.2:1 in '87? I'm sure it's simple if you have 2 in front of you that don't look the same but so far I have only removed one set of pistons and one other head and those pistons all look the same. Does anyone have a picture that shows the differences? It should be pretty obvious when looking at them next to each other right? Or maybe I can tell from the other code stamped on the engine? Thanks for the help guys.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Redline Racer
These are 9.5:1 CR pistons. (ebay pic from a '84 944)
![]() Here's the 10.2:1 pistons. (from Aftermarket pistons for an NA???) ![]() There are also ero spec 10.6:1 CR piston with an even smaller circle, but I can't find a picture of them.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 11-06-2007 at 09:31 PM.. |
Thank you much. Looks like I've got me some 10.2 pistons.
I dont think any of the 87 had 10.2 only 88 and up, but I could be wrong
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
Burn the fire.
It may be 1987 build date with 88 model year.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
I think that link is wrong. I Know the 924S doesnt have a 9.7/1 cr and Im pritty sure that all 1987 944 had the 9.5cr not the 10.2, Well at least must stuff besides that link and the pelican chart that I have read shows different numbers. I think its time to find the true answere, I'LL see what I can find just to make sure cuz I might be wrong
That Guy
'87 944 has 9.7:1 according to my owners manual..though the general consensus is all 944's from '83 - '87 had 9.5:1...this is because there is no difference in pistons between '87 and prior years. I could be wrong on that though.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Dave 82 928 Weissach #14 |
That Guy
I dont think that information is correct. I know for a fact my '87 does not have 10.2:1 pistons (ive had the head off before). Owners manual states 9.7:1 .and almost all other factory documentation (specs booklet and factory manuals) all state 9.5:1. Only '88 models had 10.2:1 .
The weights also off i think... maybe add 150lbs to each curb weight to get what the owners manual (and the general consensus of most people) say they weigh.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 11-07-2007 at 05:58 PM.. |
Thanks Jon,
I was wondering if that was correct or not. I'll belive you.
That Guy
Well ill say this, i wish it was correct. I wish my car made 158hp (which is correct for a 10.2:1 compression) and i absolutely wish it weighed 2637lbs. In reality its probably sub 147bhp after 100k miles and 20 years, and probably around 2800lbs.
Hopefully after the test pipe goes in it will be back at 147bhp and after i get these fiber glass bucket seats in, in the sub 2700 range.
winter-hater club member
my car was weighed at the last safety inspection. it came out to around 3200 pounds with the tech guy in it and a full tank of gas. the specs say something like 2900, so i think the above information is correct, at least for my car.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
