NA TPS sensor
So I was just reading the mega squirt post and I totaly forgot that the NA's dont have tps sensors, This might pose a problem for me when I tune with the MAFTERBURNER, Anyone fit a tps sensor to a t-body, How hard do you think it would be?? Can I tune without one?? I think it will be ok with out it, Just wanted to know what you guys think
Link to Mafterburner for more info on what it is, http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=944MAFTERBURNER |
Um, to the best of my knowledge, all 924S, 944 & 968 have a digital Throttle Position Switch. Are you referring to an analog Throttle Position Sensor?
I thought the NA 944/924S only has a WOT sensor not a 0-5v tps sensor
Motec & Electromotive have a sensorto fit the D shaft,
drew1 |
After reading the literature, I would suggest you call Lindsey Racing directly. I am strictly a layman in this area but it does seem to me that Lindsey has been around Porsche products for a long time.
| All times are GMT -8. The time now is 10:18 AM. |
