exitwound's Avatar
Clutch Bleeding...How much more does it want??
New master cylinder installed.
New Slave cylinder installed a few months ago.
New blue hose from reservoir to master cylinder.
Master cylinder had failed and I had to do a complete replacement. After a week of fighting, it's in.
I'm attemping to bleed the clutch system.
  • Drained the old fluid from the reservoir.
  • Topped it off with new fluid.
  • Pedal goes to the floor, obviously.
  • Been doing the method of clutch down, open bleeder on slave, close bleeder, pull up clutch (topping the reservoir every 3 or 4 times) all day. There are no signs that the clutch is getting any stiffer. Been through 1.5 pints of brake fluid so far.
  • Fluid comes out of the bleed valve smoothly without any noticable air bubbling.
How much more should I expect to have to do this? First time bleeder here.
-Patrick
Black 1986 944
Old 12-12-2007, 02:21 PM
meister member
speedracing944's Avatar
I use the Motive Power bleeder with good results. Others guys here recomend jacking up the rear of the car to bleed. Hopefully they chime in...
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-12-2007, 07:58 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Either lift the rear so you can fill the resevoir properly or get a motive. I've tried every other way and those were the only 2 that got me a stiff pedal.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-12-2007, 11:50 PM
Eldorado's Avatar
i think your method is wrong, unless i misunderstood.
as the pedal is travelling down, open the valve... and close it before it gets to the floor.
lift pedal
repeat.
you wanna open and close that valve *as the pedal is moving*.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 12-13-2007, 12:22 AM
exitwound's Avatar
What's the difference between closing the bleeder when the pedal is going down, and completely down?
-Patrick
Black 1986 944
Old 12-13-2007, 06:17 PM
earlr85944's Avatar
it lessens the chance of trapping air in the system
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-13-2007, 06:27 PM
Eldorado's Avatar
bingo
you want to close the valve as there's positive pressure in the system.
tip: jack the rear of the car up as high as possible when doing this... make sure to put stop blocks behind the front wheels.
I've now done this four times on my car... 5 or 6 pedal pushes and it's solid.
Kyle
Old 12-13-2007, 07:01 PM
exitwound's Avatar
I now get full liquid out of the bleeder valve but I still have no pedal pressure. It goes to the floor without any hesitation at all. What am I doing wrong????
Edit: clutch seems to be bled perfectly. opening the clutch fork viewport shows that the slave piston is not moving enough to push the pressure plate away. it's traveling (pushing the fork) only about 1/8th of an inch in, and retracting the same amount. New slave though. Fork seems to be okay ( no cracks etc). The slave rod is just not pushing far enough.
I cant' get the slave cylinder off!!! Stupid 2nd bolt will NOT budge. Other one came off just fine though, of course.
-Patrick
Black 1986 944
Old 12-14-2007, 08:11 AM
