-   -   Converting 944S2 cabrio (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/382197-converting-944s2-cabrio.html)
gwl123 12-12-2007 07:45 PM
I like the classic lines of the 944 to the 968. I know the 968 has the tiptronic but would like to know if its costly and complicated to convert a 944S2 cabriolet from a manual to an automatic. The automatic gearboxes are dirt cheap.
944 Ecology 12-13-2007 03:36 AM
Won't work, unless you have a one-off flywheel made for the car.
The ignition timing for the S2 is calculated off the flywheel position by teeth on the flywheel.
Since they only made manual transmission S2 cars, you would have to engineer and have one made. Plan on spending about $5K to have that work done.
Of course, if you are a mechanical engineer and have your own foundry and machine shop, that might be cheaper.
idesign635 12-13-2007 08:03 AM
I am not sure, but you maybe able to use the 968 tip setup. You would need alot of the 968 parts ecu, trans, flywheel/damper, etc.
Still not cheap
adrian jaye 12-14-2007 04:47 AM
the main thing I would ask is "why ?" :confused::confused:
fast924S 12-14-2007 01:50 PM
I think this is the first time I have ever heard someone wanting to convert a manual to automatic, usually its the other way around, Autos suck and eat HP
