hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Interor Lighting List
Hello everyone,
I was wondering if anyone has a list of the bulbs needed for the interior lights. I can not find my manual and looked at a few places on line, but can not find the list. I figured someone might have a PDF or other document with the info. I am looking for the list of bulbs needed, for dash, ash tray, glovebox, defrost adjustment etc. I am looking at replacing all the lights inside, due to old dim bulbs want to get some brighter ones. Thanks for the Help, Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 12-25-2007, 12:03 PM
GostRidr's Avatar
Hey Mike,
If you haven't already, go check out Clarks-garage.com. There is an excellent procedure on there for upgrading your dash lights and the reflective cover behind them. I don't remember the bulbs I used but am pretty sure you will find it there. Pretty easy upgrade well worth the time it takes.
Good luck!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 12-25-2007, 01:10 PM
Ichecked out Clarks, I am going to do that up-grade when I chenge the lights out. I was needing a p/N; list of the bulbs needed to replace all the lights inside, I could not find that on Clarks, I know I saw it in my Owners manual, but I can not find that, and it is not in my Haynes. Thanks Mike
Old 12-25-2007, 02:52 PM
in denial
juVius's Avatar
this link has the instrument panel light part number:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_ELlite_pg4.htm#item17
Steve - 83 944 (auto)
http://i136.photobucket.com/albums/q...s/blue/sig.jpg
Old 12-25-2007, 03:05 PM
in denial
juVius's Avatar
this one has some interior lights:
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=944_USA_82_85_KATALOG&Illustration=905-20&Line_Item=1
Old 12-25-2007, 03:07 PM
in denial
juVius's Avatar
did those links work for you?
Old 12-25-2007, 03:23 PM
It helped me to find a few of the lights, here is a list below of the P/Ns:
OEM-99963113090 – Bulb, 0,30 W – Bulb inside light selector knob
OEM-94464190000 – Bulb – Digital Clock
999-631-018-90-M97 – Bulb for Interior Light, Between Visors, and trunk
900-631-115-90-M97 – Bulb for Engine Compartment
900-631-019-90-M97 – Instrument Bulb X3 Plug-in Type
OEM-92864198300 – Instrument Bulbs X6 Turn signal, Oil etc
Now I need to find the bulb P/Ns for the following:
Ash Tray Light
Defrost Vent selector in the middle of the dash
Old 12-25-2007, 06:29 PM
in denial
juVius's Avatar
try this:
http://www.pelicanparts.com/PartsLookup/HTML/944_USA_82_85_KATALOG/903-00-Frame3.htm
Old 12-25-2007, 06:40 PM
in denial
juVius's Avatar
not sure by what you mean by Defrost Vent selector in the middle of the dash. i'll keep looking though
Old 12-25-2007, 06:41 PM
in denial
juVius's Avatar
is it here?
http://www.pelicanparts.com/PartsLookup/HTML/944_2_USA_85_88_KATALOG/903-00-Frame3.htm
Old 12-25-2007, 06:42 PM
