Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
I broke my idle adjustment!!!!
OmG! ok so if you have been following my post about my idle issue you know that im waiting on some parts to swap around and narrow down the issue. today i thought i would just turn my idle up a 1/4 turn so i can at least idle at a stop light above 300 rpm.
so i took my 10mm and....snap! i nearly passed out. now this didnt move the screw so i figured i was cool until i had a chance to put the other throttle body on. so im driving around and my car was idleing at 1000. i thought it fixed its self. this car was running better than ever.
a mile or 2 later it was at 1500, then 2000 with in a few miles i was at 4000 rpms and looked like a moron trying to shift. of course i hit every light on the way home. so i get home and see that the screw had worked itself out.
so rather than risking snaping the screw on the other throttle body, i just swapped it all out.
its sticking. idles great runs good but the throttle body seems to be sticking open just slightly making it idle at about 1700 rpm.
i have to lift the hood and manually move the trottle back to a normal position where it idles a little high.
can this be fixed or should i put the old one back on with the screw from the other?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 12-28-2007, 10:20 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I would check out why it's sticking and see if I could fix that. Try some lubricant or maybe take it off and clean it.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-28-2007, 10:33 PM
Rockin' NW Arkansas
i was afraid you would say that. i wanted someone to just say "just close your eyes and cout to 5"
Matt
Old 12-28-2007, 10:43 PM
meister member
speedracing944's Avatar
Just close your eyes and count to 5.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-29-2007, 02:28 AM
Rockin' NW Arkansas
lol
Matt
Old 12-29-2007, 06:35 AM
