Engine Block - what to do?
here's my spare engine block that i finally had a chance to take out of the box today, and sure enough what i was mostly afraid of became a reality - #4 cyl is scoured with one single line :(. I wanted to rebuild my spare engine, but now i don't know what to do - i really wasn't banking on having it re-bored.
http://i115.photobucket.com/albums/n...ber2007015.jpg http://i115.photobucket.com/albums/n...ber2007014.jpg |
Hey Dan,
Sorry I'm no expert on engine rebuilds. What is involved in having it re-bored? Expensive, time consuming? I think the expense probably comes in matching new cylinders to the new bore yes? Good luck! |
Here is a short post to answer a few Qs. I hope your scratch is only barely fingernail felt.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/256989-cylinder-honing-regarding-ccyphers-post.html?highlight=scratched+bore What is the condition of the block in your car? John_AZ |
Then again if the scratch is barely perceptible there are countless people that have just re-ringed it knowing it isn't 100% perfect and drive it for years. It doesn't take much carbon to cause a scratch. I have a spare block with serious #3 scoring from a bad injector. I measured the bore and it is a candidate for resleeving only or possibly the maximum cut on a rebore. By the time you spend $500-$700 on quality Sunnen machine honing you still need oversize pistons that push you another $700-$900 in debt. IMO at that point you might as well go big with Darton's and at least get a performance upgrade in the process.
If this were your only engine and you needed to get back on the road I would say go for it. Being a spare block it might not be worth the effort just to have an extra motor. |
| All times are GMT -8. The time now is 05:03 PM. |
