Certified Porsche addict
The Glademister's Avatar
Results of running 89 oct?
Of course the owners manual mandates 90+ octane fuel but at todays prices, wow. What are the effects in performance, maintenance and damage of operating on 89 octane without ethanol?
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 01-15-2008, 04:50 AM
adrian1's Avatar
Well the real reason is that the higher grade fuels prevent knock or detonation, which will make it run smoother and last longer. I'm not sure about the 924s but in 951s, the car will go into safe mode if excessive knock is present.
-Adrian
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 01-15-2008, 05:57 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
I thought the 2.5L NA models specified 87+ in the owner's manual?
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 01-15-2008, 06:19 AM
meister member
speedracing944's Avatar
I have run 10 years with 87. no trouble yet. The only difference you will see with running a higher octane would be your wallet will be lighter.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-15-2008, 07:09 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
the 90 octane specified in the owner's manual is the european rating, which equates to 87 octane in the U.S.
If you have a stock 944 with no chips, etc., you're fine running 87.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-15-2008, 08:12 AM
No issues in my 924S with the 89 octane. No knocks or pings. I would think dropping done to like 85 with ethanol might not work so well.
Old 01-15-2008, 12:47 PM
Redline Racer
HondaDustR's Avatar
I don't know, but I just run 93 just to be sure, since I like to rev high through the gears and start quickly off the line alot, and it's not much more expensive than the 87 where I get it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-15-2008, 12:56 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
The '88 NA states 91 in the manual and on the gas cap. That and a Wilks chip require me to run 91 :-) All I can say is that this is going to be another Octane debate thread.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 01-15-2008, 04:23 PM
I recently installed a wilk's chipped DME and am running 87 octane in my 83 944 with no known ill affects heard. I don't think that my 83 engine has any knock sensors and wanted to know if others have tried this as well? Car still runs the same with the chipped DME as it did with the stock DME. I would think that if I was hurting my engine that I would hear or feel it.
Old 01-15-2008, 05:32 PM
I don't think it's a horrible idea to run 93 or 91 octane in a car as old as ours, but it does in fact say 87 octane for US models on the NA 2.5L cars.
1998 Honda Accord
Siena College '08
Old 01-15-2008, 07:26 PM
Eldorado's Avatar
running the higher octane will, i've heard, cause carbon deposits in your engine...
I too have a wilk's chip and use 87 most of the time..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 01-15-2008, 10:26 PM
The owners manual on my 85.5 states: Minimun octane rating of 91 RON (87 CLC or AKI rating on fuel pumps in the U.S.A.). I'm sure others have seen this too. I don't know what CLC or AKI means. Maybe somebody can tell me. I know that RON is research octane number and that the MON (motor octane number) is usually 4 points less. So if you do the R+M/2 then that spells midgrade or 89.
I would be interested to know the boundry if there is one in terms of the compression ratios and octane requirements. Is a 9.5:1 compression ratio enough to ignite ALL of 93 octane?
Regards Dietrich
Old 01-16-2008, 07:26 AM
Eldorado's Avatar
probably not... but i haven't done the math...
Kyle
Old 01-16-2008, 07:52 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
It's my understanding that the octane has more to do with ignition timing than compression. Different octanes have different burn rates/ignition points and you have to set the timing accordingly. That's why the wrong octane will often cause spark knock until you put the right octane in it. The knock sensor will often times help the computer recalculate the timing which is what it's there for.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-16-2008, 07:59 PM
One apex at a time
Dean924s's Avatar
In layman's terms the higher the octane the slower the burn and the more stable the fuel when compressed (less likely to pre ignition) Run the cheapest gas you can that does not knock.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 01-16-2008, 08:15 PM
^ What he said.
Tom
Old 01-16-2008, 10:20 PM
Eldorado's Avatar
indeed.. and throw in a tank of the good stuff every couple months or so just for the benefits of the cleansers in the fuel.
Kyle
Old 01-18-2008, 04:06 PM
