Mein Gott!
Panzer909's Avatar
Can't find the ISV - 944S
Okay I give up. Thought I'd do some engine bay cleaning and stuff as the great weather continues here in PA. But when warmed up, the car seems to sit at about 1200RPM...I think this is a little high.
Time to start troubleshooting. Looking at the parts diagram for an S here on the Pelican site, I'm having an awfully difficult time finding the ISV on this car. Anyone got a pic?
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 01-12-2008, 04:55 PM
I'm assuming ISV is the idle control valve? It's located under the intake manifold and can be seen by looking from the passenger side. It's very hard to get to and I've heard that you have to remove the intake manifold to service it - unless you have small hands.
Old 01-12-2008, 04:59 PM
Mein Gott!
Panzer909's Avatar
Yep - The idle control valve. I was hoping someone wasn't going to say it was located there
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 01-12-2008, 05:00 PM
autoxr's Avatar
Send a message via AIM to autoxr
Doesn't it require a 6mm socket....very small, no? to turn the screw
1983 Scirocco (RIP)
1983 911 SC (SOLD)
1987 NEUN44S #8 SCCA-NNJR
1999 Volvo XC
2000 Suburban
Old 01-13-2008, 07:21 PM
GostRidr's Avatar
If you are going to go in and replace, like I did, I would recommend ordering some new rubber/bolt/bushings. These are the same part that help your AFM 'hover'- a bolt on top and bottom with a rubber center. Mine were thrashed and I had to wait to order some in. I don't remember Pelican having these before but haven't checked in awhile. I think I found them at 944online.
You going to do it yourself or send it in?
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 01-17-2008, 08:10 PM
Mein Gott!
Panzer909's Avatar
Its against my religion to take the car to a mechanic.
I'm basically prowling for something to tinker on. From what I can see, the throttle switch is covered with a thin film of oil. I'm a bit frustrated at the throttle setup on 16 valve cars; they're foolishly complex for no apparent reason and the TS is almost buried under everything and considerably more difficult to access as opposed to the 8v cars. Jeez.
Okay. Fine. I'm probably gonna just take everything apart. Arnnworx says there's a few seals that go bad in the throttle body that cause the oil blow that could lead to the higher idle I'm having. The ISV will be tacked while I'm at it I suppose. This has weekend garage project written all over it!
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 01-18-2008, 05:26 PM
harryrick's Avatar
Its quite common for it to get gunked up...I was tweeking things and after adding a hi flow cat the idle loped...I thought, WTF? So...I got a can of tb cleaner and ran it thru. On the top of the intake near the throttle cable there's a "port" I'll call it...I undid that, dumped some cleaner in and put her back on. The car smoked like crazy for about a block and a half, but it cured the idel lope, and the car has run A1 since.
Rick, Chatsworth, Ontario, Canada
1988 944S
18" 993TT wheels
Magnaflow hi performance exhaust
K & N air filter and MaxHP Kit chip
Old 01-18-2008, 06:15 PM
Mein Gott!
Panzer909's Avatar
A "port"?
Got a pic?
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 01-18-2008, 06:17 PM
gtroth's Avatar
Yeah, on the S you'll want to pull the intake to service the ISV or even the throttle (it is called "ISV" for 16V cars, btw).
It helps to remove it as one big assembly - see here:
http://forums.rennlist.com/rennforums/showthread.php?t=225497
With the manifold out there's a long list of things you could now do in addition to the ISV, of course (AOS seals, engine grounds, IM gasket, ref/speed sensor, TPS, throttle rebuild, temp sensor, vacuum lines, good time to rebuild injectors)
FYI - removing the IM the second time is really easy.
1995 993C4 guards red
1988 944S alpine white
Old 01-18-2008, 07:15 PM
Mein Gott!
Panzer909's Avatar
gtroth- can you post that attachment pic here? I accessed the rennlist link but it doesn't let nonmembers see pics. Thanks.
Johnny
1987 944S
1984 944 (R.I.P.)
2003 BMW 325xi
Old 01-18-2008, 07:19 PM
gtroth's Avatar
--sorry, didn't realize RL started doing that...
Anyway, turns out I cross posted that one here:
help - 944S venturi connection (x-post)
Old 01-18-2008, 07:32 PM
