cycling has-been
bkreigsr's Avatar
flex hose size from brake reservoir ??
can anyone tell me the correct size (od & id) of the flex weave hose that runs from the brake fluid reservoir fitting to a nipple on the firewall?
might be just an overflow drain?
it's about 10-12 inches long
the exploded parts diagram on pp doesn't show it (that I can identify)
car is 87 944S
thanks
Bill K
Old 01-14-2008, 07:47 AM
earlr85944's Avatar
here is the correct hose on -bay
http://cgi.ebay.com/ebaymotors/NEW-PORSCHE-911-924-928-944-968-CLUTCH-HOSE_W0QQcmdZViewItemQQcategoryZ33730QQihZ006QQite mZ160196833579QQrdZ1QQsspagenameZWDVW
its the low pressure hose from the brake res to clutch master cyl
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 01-14-2008, 09:27 AM
cycling has-been
bkreigsr's Avatar
thanks
my younger son just got a hold of his brothers 944S that had been on the west coast (idle) for the last 5 yrs, & I'ver been going thru it to get it road worthy.
I thought the blue color was the hi-temp brake fluid seeping through.
Did not know the hose innards are blue, but will replace anyway.
Bill K
Old 01-14-2008, 09:52 AM
cycling has-been
bkreigsr's Avatar
any tips on replacement?
will a hose replacement introduce air into the system to the point I will have to bleed the system?
thanks
Bill K
Old 01-14-2008, 10:47 AM
earlr85944's Avatar
you can minimize air intro by, and yes this can get messy
-have rags under the hose to catch any spillage
-have a helper depress the clutch pedal and brake pedal simultanously
-replace the hose and use new clamps, leave bottom clamp loose
-make sure res is full and loosen lower clamp and let fluid gravity drain out the bottom of the hose to get the air out, dont let the res go empty!
tighten and release the pedals
my theory behind this is that the return stroke of the pedals will force back any residual air into the res where it can escape
also a nice time to go to the super blue fluid with a brake system flush....
83 944....bye bye
Old 01-14-2008, 11:47 AM
TNT25169's Avatar
Send a message via AIM to TNT25169
www.*****************.com also has it. I believe it's known as "the illusive blue hose" due to the fact you can't find it at any parts store or dealership.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 01-14-2008, 11:54 AM
Used & Abused
It helped alot for me to suck out most of the brake fluid from the reservoir with a vacuum bleeder. Much less fluid mess.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 01-14-2008, 05:04 PM
cycling has-been
bkreigsr's Avatar
I bought a hose from the ebay link and installed it today.
Suggestion - prefit both ends to a similiar size nipple to stretch the inner diameters a bit before attempting to fit on the firewall nipple.
what a pita
thanks for all the input
Bill K
Old 01-19-2008, 05:02 PM
