Does anyone know where the Hood Light swich is located?
Trying to find the location of the Hood light switch. I can trace the wires to the connector then to the harness, then is gone into the car. I have no power, so I know the switch is either missing or is not working. Beein trying to find in parts, but I must be a tard. Someone got a pic or location? Thanks Mike
I Love the Smell of Jet Fuel in the Morning! 86 Silver Porsche 944 N/A - Alpine CDA-9857 KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade http://www.c28.com/?adid=st&iid=25349 |
in denial
there isn't a hood light switch... it comes on with the headlights.....
I though ti was set up like the other cars, that when you raise the hood, the light would come on, so you can see the engine in the dark. Why woudl it be set up to the headlights? I am use to the old Chevys! Sorry about that then.
in denial
it took me a long time to figure that one out to.....
pretty sure the switch is located inside the bulb housing
1983 Porsche 944 1966 VW Bug |
in denial
One neat feature I recently discovered is that with the lights out and the hood up, if you turn the turn signal stalk up one notch as if you were signalling to the right (left-hand drive car) the engine light comes on!
