My vents constantly blow hot air? why
What isnt functioning properly that constantly blows hot air into my 944 n/a 87' cabin. Thanks Josh
1987 944 n/a
Old 01-23-2008, 11:49 AM
That Guy
Techno Duck's Avatar
Plastic clip is probably broken. Search for 'plastic heater clip' and a multitude of threads will turn up.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-23-2008, 12:22 PM
Also check your Brake Booster Check Valve. There is a tiny port and the vacuum line that connects to it controls the heating system. I accidently broke mine well wiping down the engine and my heater was stuckl on until I fixed it.
Vern
Old 01-23-2008, 01:25 PM
scottcip1562's Avatar
Check you heater control valve. Part number from our host.
944-572-085-02-M53
79SC, Wevo Shifter, SSI, Koni's, MK Muffler
85 944 Stock
Past Porsche's
87 944
87 928S4, I was young and dumb
99 Boxster
70 911T
Old 01-23-2008, 04:45 PM
Non Compos Mentis
Stick your head under the dash, towards the center. If there is a little shaft dangling, it's because the plastic clip that holds it to the hot/cold mixer valve broke, leaving the valve in the full hot position. The clips are getting brittle by now.
Old 01-23-2008, 09:25 PM
I had the same problem in my 944 n/a 1/'85. Turned out to be a faulty heater control valve. The valve was worn and would not completely shut off the hot water/fluid going into the heater, thus the heater radiator (or heat exchanger) was permanently producing hot air .
Bought a new valve from our host, replaced it and the problem was solved.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 01-24-2008, 08:10 AM
944-572-085-02-M53
I believe that part number is for cars up to 1/85, for his '87 the part number seems to be
928-574-573-03-M53
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 01-24-2008, 08:14 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
wrong area.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 01-24-2008, 01:58 PM
Super Moderator
nize's Avatar
+1 on the heater control check valve.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-24-2008, 06:42 PM
