early and late carpet question????
if i buy a carpet set for a 1983 that was meant for a later 944 (LOW price), what are the MAJOR differences. is that hatch area the same? the door parts and gearshift area are different but COULD they work without looking weird?
thanks guys!!
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
i looked at some early threads that state that they seem almost the same. so that would be enough info. thanks again.
e
One thing that I discovered when I bought a used hatch carpet last year is that the "wings" on the sides that cover up the wells behind the rear wheels are different between a power sunroof car and a non-sunroof (or a manual roof) car. The motor and relay panel on the driver side makes the "wing" on that side about an inch or two smaller.
Dan Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc. |
Trying to work for parts!
Most of the carpet is different. I've tried this. You can use most of the carpet from an early car, but not all.
Hatch carpet is different, but can be used. Rear sides - Will be fine Back seat floor - Almost identical, you can use it. Front seats - You can use it, but it is the one piece that is very different from the rest. Would require cutting. Wouldn't recommend using this piece if you want things to look really good. Kick panels - Think these are identical
86 Metallic Grey 85.5 Metallic graphite - Gone |
