thoen's Avatar
Cool hatch seal question
hi,
i have had some trouble finding the numbers for the hatch seals. it seems that the one on the lid/hatch is part # 944 512 043 00. what is the number of the bottom seal that is on the car itself?
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 01-30-2008, 10:05 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
That's all there is. There isn't more then 1 seal.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 01-30-2008, 11:25 AM
That's the seal that's on the car itself. But if you've got a leaky hatch that probably won't fix it. I had to re-seal my hatch window to fix the leaks.
Astoria, NY
Old 01-30-2008, 11:43 AM
Resealing the glass is different. It's not a rubber seal. It's basically glue. What you had was glass seperation. known to happen on these cars. Not an easy fix in the least and not for the faint of heart. Most recommend to just replace the hatch with a different used one.
86 Metallic Grey
Old 01-30-2008, 11:48 AM
You're right, and it was worse than replacing the water pump! I used the 3M primer and Windo-Weld urethane stuff which works great. Ernest, I hope you don't have to go through what I did! Best of luck with the hatch seal.
Astoria, NY
Old 01-30-2008, 12:22 PM
thoen's Avatar
i just checked and you guys are right. Thats the seal I need!!!!!!
Old 01-30-2008, 12:29 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If the problem is you are getting fumes in your car...then get a new seal...if it's water...then you need to look at the window being glued to the window frame.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-30-2008, 01:32 PM
thoen's Avatar
i am having water problems. when the car is tilted backwards, there is no problem. when the car is tilted forwards, water gets into my back seats and carpet. my sunroof is not leaking and the drain by the drivers column, i just replaced. the glass is perfect without any separation. the seal is old but looks soft and pliable. perhaps TOO pliable and it is dented by the top two hinges. i have tried all of the obvious. it has to be getting in from the top and leaking inwards. it's hard to tell when its raining but....
Old 01-30-2008, 03:22 PM
Since you said you replaced the drain....Was it leaking before you did that?
86 Metallic Grey
Old 01-30-2008, 03:31 PM
Take a garden hose out there and try to watch where it's coming from.
Tom
Old 01-30-2008, 03:55 PM
