starting problems
maybe its because i live in michigan and its crazy cold here sometimes but ive been having this problem. my battery keeps dieing overnight i guess or when it sits all day. Ive gotten the batt tested and the alternator tested both came out perfect. Even after i got the bat fully charged at a near by store and i turn the car on, the bat meter jumps depending on what i turn on. It goes from 14 to under 12 if i turn on the defroster, lights, rear defrost which is the worst. i really dont know what to do. Also at times when im driving or reving the engine you hear a whistle noise come from the alternator area. Not a screech but more a loud whistle.
any help or input would be greatly appreciated
ty
85.5 944 N/A Chestnut Brown Metallic
Autothority Performance Chip
hoping to grab some 18" rims
Custom cat-less exhaust to come in the spring
Old 02-28-2008, 04:21 PM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Well keep us upto date. I could not even tell you where to start. I have learned that there are a lot of electrical problems with the 944s and it takes a lot to learn them. My car is getting better, but I am doing it part by part and learning from these guys on Pelican. Be sure to check your grounds real good. That was one of my first problems I was having, gauges doing some stuff lights etc. Went through all my grounds cleaned real good and sprayed a corrosion preventative on them. Once I got through everything, it worked a lot better. Even go through the cables on the battery and the starter and alternator. Easy things first might help. Hope this helps out, Mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 02-28-2008, 06:16 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Here is how I do it. I take the negative battery cable off the battery. I get a meter with a 10 amp reading and clip the negative lead on the battery post and the positive lead on the battery cable you just took off. This will tell you the amperage traveling through the meter. Should be less than 100 mA. Actually ideal is around 60 I think. Car should not be running and all doors should be shut and all lights off. Anything that should be shut off normally over night should be off. That will give you an indication of how much electricity is being pulled while it's sitting overnight in the driveway.
If the amperage being pulled is about 100mA, then you need to look for something pulling power and draining your battery. With the amp meter in place as described about, start pulling fuses and relays until you pull one and the amp meter reads under 100. That will tell you the circuit that is pulling the power and then you need to start unplugging items on the circuit to find which one is bad. Some of the common things that cause this is the heater connectors on the rear hatch glass and the door light switches that run the light when you open the doors. You might try those two circuits first.
Once you get your battery drain levels down to an acceptable level, the battery will stay charged.
Just thought of something...when running the car, does the voltage read around 14V? It could be the charging wire isn't carrying current to the battery because of corrosion or poor connections somewhere. If the current drain is under 100mA, then start looking for dirty or bad battery cables or the alternator connection on the back of the alternator or the connection on the starter.
The amount of battery drain will tell you which path to pursue.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-28-2008, 08:45 PM
