In over my head
Question Can't get Alternator belt off - any ideas?
I am replacing my alternator and cannot get the A/C compressor out of the way far enough to slack the belt off. I have followed the Clark's Garage item by item, but A/C compressor just does not want to move far enough toward the block to slip the belt off.
Can anyone offer any ideas?
TIA
Fergus
86 951 Graphite Metallic
86 944 n/a Garnett Red Metallic (SOLD!)
74.5 Triumph TR6 (restoration project)
05 Subaru Legacy (winter car)
Old 03-27-2008, 01:48 PM
Have you tried removing the turn-buckle tensioner completely? Also, there may be a bolt that keeps the alternator from swiveling easily - this may have to be loosened.
Vern
Old 03-27-2008, 01:59 PM
In over my head
Turnbuckle completely removed. Any idea where the additional bolt is?
It's not like I have not been able to get it to move, but rather have not been able to get it to move enough.
Fergus
Old 03-27-2008, 02:01 PM
Learned by do'n twice
Use a large screwdriver between the belt and the pulley and pry it off.
jmd_forest
86 944 NA - Brought back from the dead
Old 03-27-2008, 02:07 PM
That Guy
Techno Duck's Avatar
Use a dead blow hammer to get the compressor farther over, or just use a hammer and piece of wood as a stand off. The belt should slip right over the pulleys regardless.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-27-2008, 02:17 PM
In over my head
Guess I am not hitting hard enough...
Fergus
Old 03-27-2008, 02:27 PM
thekidd's Avatar
Send a message via AIM to thekidd
if you replacing the aletrnator, then just take the alternator out. That would eb an easy belt removal.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 03-27-2008, 02:51 PM
In over my head
Dead blow hammer worked... Now to figure the right orientation to get it back in... It's a 951 so space is at a premium
Fergus
Old 03-27-2008, 06:11 PM
I ran into the same problem yesterday.
I used a pair of wire cutters. Simple.
1986 951 Sold
Old 03-27-2008, 08:22 PM
if you're replacing the alternator AND the belt, you can always just cut the belt.
'86 951 Guards Red, MBC, Adjustable FPR, Venturi Delete, LR Exhaust
Old 03-27-2008, 09:09 PM
In over my head
All is done and back in took a mere 6 hours... Correctly I hope... I am seriously doubting my wrenching skills. How in the world did they put these cars together?
Saved the belt - which was in great shape, but had thought about the cutting it route as I do have a spare.
Many thanks to all for their assistance.
Fergus
Old 03-28-2008, 07:34 AM
