In over my head
I am replacing my alternator and cannot get the A/C compressor out of the way far enough to slack the belt off. I have followed the Clark's Garage item by item, but A/C compressor just does not want to move far enough toward the block to slip the belt off.
Can anyone offer any ideas? TIA
Fergus 86 951 Graphite Metallic 86 944 n/a Garnett Red Metallic (SOLD!) 74.5 Triumph TR6 (restoration project) 05 Subaru Legacy (winter car) |
Have you tried removing the turn-buckle tensioner completely? Also, there may be a bolt that keeps the alternator from swiveling easily - this may have to be loosened.
Vern |
In over my head
Turnbuckle completely removed. Any idea where the additional bolt is?
It's not like I have not been able to get it to move, but rather have not been able to get it to move enough.
Learned by do'n twice
Use a large screwdriver between the belt and the pulley and pry it off.
jmd_forest
86 944 NA - Brought back from the dead |
That Guy
Use a dead blow hammer to get the compressor farther over, or just use a hammer and piece of wood as a stand off. The belt should slip right over the pulleys regardless.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
In over my head
Guess I am not hitting hard enough...
if you replacing the aletrnator, then just take the alternator out. That would eb an easy belt removal.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
In over my head
Dead blow hammer worked... Now to figure the right orientation to get it back in... It's a 951 so space is at a premium
I ran into the same problem yesterday.
I used a pair of wire cutters. Simple.
1986 951 Sold |
if you're replacing the alternator AND the belt, you can always just cut the belt.
'86 951 Guards Red, MBC, Adjustable FPR, Venturi Delete, LR Exhaust |
In over my head
All is done and back in took a mere 6 hours... Correctly I hope...
![]() Saved the belt - which was in great shape, but had thought about the cutting it route as I do have a spare. Many thanks to all for their assistance.
