salcaroprese
salcaroprese's Avatar
944S no spark - power into distributor
My 944S will not start. I have power (12 volts) into the distributor but i am not getting spark. I don't have power out of the distributor. I have tested and cleaned the distributor cap and it tests fine to all terminal points.
The only thing I can think of is the cap and rotor are worn to the point where there is too much of a gap for spark to project(seems unlikely). I have ordered a new cap and rotor will be here next monday. The coil and ignition control module are new. Reference sensor tests good.
87 944S
Old 03-30-2008, 02:55 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Put a plug into the wire coming from the coil and see if you have spark on the plug. If so, you know you have a spark going into the distributor and the problem is in there. I would also check the rotor and make sure you can't turn it on the shaft meaning the set screw is loose or missing.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-30-2008, 10:29 PM
