More TDC Questions
Well, Sundays are my day to work on the Porsche... I was planning on AT LEAST getting the belts off, the cam tower off, and MAYBE even the exhast manifolds...
Well, I wanted to MAKE SURE that my engine was at TDC. The camshaft gear notch lined up, and I looked into the flywheel inspection hole and saw what appeared to be the TDC marker (a black line running across). Just to make sure, I cranked the engine another 180 degrees... and saw, in the flywheel inspection port, what looked like a TDC marker on the flywheel. Now, doesn't the camshaft turn twice for every rotation of the flywheel? Shouldn't I be seeing a TDC mark on the flywheel every OTHER time that the camshaft gear notch matches up with the mark? MORE CONFUSED THAN EVER! |
The Crank turns twice as fast as the cam, have a look at the pully sizes.
So as long as I can see a mark on the flywheel, and the cam gear is lined up, i'm ok?
Yep, I wouldnt get too hung up about it if your pulling the top end anyway things will be much clearer.
As long as you turn it over by hand with a wrench on the crank nut before trying to start it when its back together you cant do too much harm |
Thanks for the info. Something tells me I'll be obsessively checking the flywheel throughout this entire process...
| All times are GMT -8. The time now is 05:31 PM. |
