Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
More TDC Questions
Well, Sundays are my day to work on the Porsche... I was planning on AT LEAST getting the belts off, the cam tower off, and MAYBE even the exhast manifolds...
Well, I wanted to MAKE SURE that my engine was at TDC. The camshaft gear notch lined up, and I looked into the flywheel inspection hole and saw what appeared to be the TDC marker (a black line running across). Just to make sure, I cranked the engine another 180 degrees... and saw, in the flywheel inspection port, what looked like a TDC marker on the flywheel.
Now, doesn't the camshaft turn twice for every rotation of the flywheel? Shouldn't I be seeing a TDC mark on the flywheel every OTHER time that the camshaft gear notch matches up with the mark?
MORE CONFUSED THAN EVER!
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-30-2008, 10:05 AM
The Crank turns twice as fast as the cam, have a look at the pully sizes.
Old 03-30-2008, 11:40 AM
Writer/Teacher
CJFusco's Avatar
So as long as I can see a mark on the flywheel, and the cam gear is lined up, i'm ok?
Old 03-30-2008, 12:04 PM
Yep, I wouldnt get too hung up about it if your pulling the top end anyway things will be much clearer.
As long as you turn it over by hand with a wrench on the crank nut before trying to start it when its back together you cant do too much harm
Old 03-30-2008, 12:19 PM
Writer/Teacher
CJFusco's Avatar
Thanks for the info. Something tells me I'll be obsessively checking the flywheel throughout this entire process...
Old 03-30-2008, 02:13 PM
