Fixing a broken 924 odometer
Is there a plastic gear inside that wears out? Any idea where to get one or a place that will fix it?
02 996TT Stick Modded AKA Tubsey
08 Cayman S 6spd 49k Black/Terra-cotta
04 Gallardo Gated 6spd 19k Arctic Grigo/Nero Blue
14 BMW M5 6spd Stick
06 Cayenne S 🌝 miles 1982 928 S 5spd :-)
Old 03-30-2008, 09:52 PM
924RACR's Avatar
Yes, it usually cracks. However, in my experience this isn't the same part as the 944's.
I don't believe Pelican sells these? Might have to have a VDO dealer repair it... heard good things about North Hollywood Speedo...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 03-31-2008, 03:58 AM
unindicted co-conspirator
looneybin's Avatar
If Pelican does not have the odo gear, try "***************" (Performance Parts) - but i would try Pelican first
Or you can send it to North Hollywood Speedo as mentioned by 924RACR if you dont want to try to fix it yourself.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 03-31-2008, 07:21 AM
I couldn't find anything on pelican but i'll look agian.
Old 03-31-2008, 08:25 AM
KLA industries has them.
They`re not listed on their website but they have them. As there are a few different speedos that have different number of teeth (14,17, xx) and I believe they are color coded (white, red, xx) count the teeth and email them. Got one some months ago and IIRC was $30.
Old 04-01-2008, 05:52 AM
As 924racr stated they sometimes crack, I was able to use super glue to fix mine (cracked). It's lasted 2 years so far.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 04-01-2008, 06:06 AM
winter-hater club member
nynor's Avatar
mine slid down its shaft (heh heh!) and just needed to be moved back into position and then glued in place. the 924 speedometer is the same as the early 944 speedometer.
"COOL PRIUS!" - Nobody Ever
Old 04-01-2008, 10:25 AM
924RACR's Avatar
Not all 924's, even early ones, have the same speedo... some go to 85, some to 170!
Vaughan Scott
http://www.924.org
Old 04-01-2008, 11:30 AM
nynor's Avatar
good point. but i think they are interchangeable, no? i had a 924 speedometer in my '83.
Old 04-01-2008, 11:42 AM
924RACR's Avatar
The speedos are interchangeable as a unit, yes!
Vaughan Scott
http://www.924.org
Old 04-02-2008, 05:54 AM
I got my gear at www.odometergears.com. The original had turned into something about the consistency of a "Gummy Bear" and about half of the teeth had sheared off. It is very easy to repair it.
...Lee
1985.5 944 N/A India Red
RIP 1973 914
Old 04-02-2008, 10:02 AM
Thanks. Any tips on install or is it straight forward?
Old 04-03-2008, 10:27 PM
looneybin's Avatar
The gear replacement is very straight forward, there is a great write up in clarks garage that covers it very well, except make sure you clean all of the elec connections before you reinstall.
Old 04-04-2008, 08:50 AM
