			 Rockin' NW Arkansas
				Hot Air thru vents?
			i have one for you gurus out there. i get a warm/hot air constntly coming from my vents. in the winter its nice.... but were coming into spring. even with the heater turned off and the temp to cold, it will still lightly blow warm air. ideas?
	Matt 1986 Porsche 928 S - Daily Driver 1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD  |
			 Misunderstood User
			The only time I truly get cold air thru the vents is in the winter time.  During the warmer weather seasons, the air is cool only in the morning but as the day progress, it becomes warm.  Honestly, the ventilating system in the early Porsches is fair.  I understand that the later 85 1/2 's is much better.
	Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway  |
			 Rockin' NW Arkansas
				hot air
			i can understand why its blowing. of course its cold when i first start it but as the car warms up it gets hotter.
			Either the cable adjusting the hot water valve is not adjusted correctly or the hot water valve is leaking. Try loosening the cable first and see if you can close the valve further. If not, then replace the valve.
	Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually  |
			Besides what's mentioned above, there is a small hard-plastic vacuum line that connects to the brake bllster.  If this is disconnected or broken, the heater will blow hot air constantly.  I discovered this when I replaced my brake vacuum line (in the summer) and accidently broke that tee fitting on the brake booster check valve.
	Vern  |
			 Back from Beyond
			I agree with Tom, but also keep in mind that the squirrel cage draws air from under the hood.
	'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE!  |
			 Garage Helper
			Hello all,
					There will be constant air blowing through the cab as it is a design factor to keep all windows from fogging any time. Along with this there is a small plastic clip that attaches to the rods that control the flaps under the dash. If this small clip is broken/missing the control flaps will not fully close allowing hot air from the front vents.
	78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word  |
