engine flush using ATF ?
I have done an engine flush on my high mileage Saabs and Volvos. I was wondering if there is any tech info on engine flushes for Porsche 3.0L motor ? Or if it needs to be done at all ? Depending on how the engine is designed, some motors cannot always clean the lifters correctly and they tend to make noise and build up sludge. I have not seen this mention for our motors, but perhaps I have missed it ? The only noise I notice out of my motor is the FI clicking, which is a "nice to have" for a 140,000 mile motor.
Flush= Good Quality Transmission (ATF) fluid in the engine at high revs for about 5 miles and then drain the oil and put clean engine oil back in.
1990-Porsche 944 S2 Project Hair Loss
2001-Saab 9-5 BSR Best car I have owned
2008-BMW 328i (Just another beamer)
Old 04-13-2008, 05:59 AM
I used seafoam in the oil (85.5 944 n/a) for a few hundred miles before changing it. My objective was to remove sludge and carbon from the rings, valve guides and lifters so they would be better lubed. I think the car had been run with conventional oil before that. After a few hundred miles the oil was very black, so seafoam certainly removed a lot of sludge and did a very good job. There was probably a lot of sludge buildup on the pan and block surfaces that got loosened and circulated around the engine.
I put in Mobile1 -5w-30- after that. Lighter oil is probably better for the lifters, rings and valve guides that have tight clearances and will also give better gas mileage. It is probably not as good for the bearings where higher stress occurs, especially if you race or drive hard. But I don't drive hard and I like the looser feel and better mpg the lighter oil gives to the engine.
The only thing I am not sure about is if there is a lot of sludge loosened up by seafoam, that it could end up in the lifters and make the lifters worse. IF the engine is sludged up bad repeating the seafoam procedure soon say in another 1000 miles might help. The commercial shops may have a way to remove sludge without running the engine.
Old 04-13-2008, 06:49 AM
earlr85944's Avatar
safest way is more frequent changes w/ quality oil
ive see leaks and even loss of pressure in therwise good running motors attempting to be flushed
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 04-13-2008, 10:42 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
I'm with Earl on this one.
But I have read where others have done this. Most lhave reported better success with seafoam though.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 04-13-2008, 12:21 PM
My 30 year Porsche Mechanic friend says 1 qt of ATF at idle (no drive) then flush. I've use the engine oil "gunk out" to flush every few oil changes. Works great and keeps your internals cleaner. Also second that sea foam is good stuff.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 04-13-2008, 12:48 PM
Talking
The last thing I need to do is create a bunch of leaks !
Old 04-13-2008, 12:51 PM
I have known guys to use diesel fuel, but never heard of ATF. I would recommend not using either! I too have seen many a leak start after an engine flush.
+1 more for sea-foam
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 04-13-2008, 02:11 PM
Certainly flushing will increase leaks in a 20 yr old car. A drip her and a drip there, but many can be handled by tightening up this and that, or replacing minor items. A major leak such as a main seal or other critical components might occur, but I defer to the porsche experts on this board on the probablility of this happening, and where most likely to occur. In any case you don't want to dump in flush, change oil, and then drive cross country with reckless abandon. Caution is certainly called for, especially for the non-DIY types.
Old 04-13-2008, 02:38 PM
Send a message via AIM to bholmes
all ATF is, is straight 10 weight oil with deafoaming agents and dye. Not sure why it would be a good flush, but certainly can't hurt.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 04-13-2008, 03:22 PM
944Spec_bound's Avatar
I once flushed the straight six engine in my dad's 65 Ford pickup with diesel fuel. It had very low oil pressure, pulled the valve cover and it was a mass of black gunk, you couldn't even see the valve springs and all of the oil return holes were plugged. I just needed it to make one last trip, so with nothing to lose, I scraped off as much gunk as i could, replaced the valve cover, put 3 qts diesel and 3 qts motor oil, let it idle a while, drained, repeated, replaced filter and oil.
Several years later we finally retired that truck with probably another 75K on that engine without ever losing oil pressure again.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 04-13-2008, 07:44 PM
I'm not saying I recommend that for a Porcshe because, though, unless you too are desperate and have nothing to lose.
My Website:
Old 04-13-2008, 07:47 PM
Eldorado's Avatar
i've used wynn's engine treatment, and really liked the results... quieted the lifters up.... and the next oil change, the old oil was dirtier than usual..
but the PO used seafoam in my car and swore by it.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 04-13-2008, 09:14 PM
adrian jaye's Avatar
from NotJustPorsche E-Group
Oil change procedure
The OverKill Method !
OIL USED: Shell Helix plus (10w-40) - the specs exceed Porsches own requirements.
SUGGESTED: Change it while its hot (after a 10-15 min drive)
PARTS: New nut and washer, 2 x Oil Filters
1> add wyns engine flush and rev at 2000rpm for about 20 mins, then drain oil
Also, disable the ignition and cranking over the engine a few times once its
drained just to help squeeze some more oil out of the system and leave it
draining for at least 30 mins.
2> Fit new Oil filter add 2.5 ltrs of flushing oil and 2.5 ltrs of cheap nasty
supermarket 20w50 and idle for about 20 mins.
3> Drain for an hour ! then re-fill with "Good" Shell oil and second Filter.
4> Then note the Clanking noise !!!
5> The noise should subside once you have driven the car through some varied
conditions (providing the lifters with varying oil pressures and loads) for
30 mins to an hour. Its quite common for this, so
DON'T PANIC... Its another reason why main dealers don't flush, because they
then have to drive the car to re-inflate the lifters.
=======IDLE for #2=================
start her up... while the engine warms up, follow a cycle of letting
it idle for 5 mins, then lifting the engine speed to 2000 rpm for 5 mins..
do not drive the car during this.. keep an eye on the oil pressure, and time
how long it takes for the radiator fan to come on.... after the radiator fan
has turned off, keep cycling the revs as mentioned for just as long as it
took from starting the engine until the fan came on and shut off.
Running in procedure
1 As soon as the engine fires up, bring the RPM to between 2000 and 2500
RPM and hold it there for the next couple of steps.
2 Monitor the engine on a 4 gas analyser and an ignition scope, make
alterations to the fuelling and ignition the whole time its running.
3. run the engine like this for 15 mins
4. Drain the oil, replace with fresh mineral oil
5. take the car out for a 20 to 30 mile journey of varied duty cycle. in
other words a mix of duel carriageway and urban, with minimum idling, and
regular use of acceleration, never exceeding 75% of the maximum engine RPM,
but using full throttle when possible.
6. drain oil and replace with more mineral oil
7. Hand car over to customer for 1500 miles, with the instructions of
8. change oil for fully synthetic and tell the customer to drive it as
they please.
STUCK NOISY LIFTERS
If you have a stuck lifter, a sticky ring, or chronic problems with black
death (oil sludge) there is a very good way to sort it out, which works in
most cases, and has been used on my 944 twice in its long life (220,000
miles on the original engine without a rebuild), once when I first got her
when the lifters were chattering through it not having enough oil changes,
and once about 30,000 miles ago when I got back to the country and she had
been standing for 2 years since my previous journey in her! So it will not
hurt the engine at all..
What you do is mix cheap and nasty 20-50 oil from a super market, in a ratio
of 50-50 with diesel.
Drain your engine oil, give the engine a fresh filter, fill her up with this
recipe, start her up... while the engine warms up, follow a cycle of letting
took from starting the engine until the fan came on and shut off (you can do
it longer than this if you want..
Once you have done this, drain the oil mix (leave it draining for an hour or
so), change the oil filter and give fresh good quality oil, something like
15w50 mobil, and take her for a carefull drive... in 9 out of 10 times, this
will cure the problem unless you have a completely knackered lifter.
Its a bit like a mega engine flush on steroids to keep in the arsonal as a
"if all else fails" idea.
It scares the hell out of most people... but you need to remember, diesel is
oil, just a very thin oil, so it thins down the 20-50 oil so it can creap
into clogged parts or defeat air locks within deflated lifters. Also diesel
contains deturgents, which help the process of moving sludge.. the only
reason we use 20-50 is that it is cheap, sufficient and gives about the
correct thickness when thinned with the diesel.
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 04-14-2008, 04:42 AM
I wonder, do they even sell detergent motor oil anymore?
It used to say right on the bottle "detergent" or "non-detergent" but not anymore.
My Website:
Old 04-15-2008, 12:37 AM
earlr85944's Avatar
the current oils are detergent, its hard to find non detergent, but napa still sells it
83 944....bye bye
Old 04-15-2008, 06:44 AM
rickharrison's Avatar
synthetic oil in a 20 year old engine = leaks
the chemicals in synthetic oil will cause the oil seals to become brittle and break down. you will eventually get a leak.
a good quality engine oil, 15 w 40 Swepco for example is best. This oil exceeds ALL performance standards, whereas most other oils (Castrol, Shell, Mobil, etc) only just meet performance standards.
I've used Wynn's engine flush, and its good, seafoam would be good too. I wouldn't use deisel its tough on seals.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 04-15-2008, 07:04 AM
Eldorado's Avatar
i wouldn't say that the chemicals cause the oil seals to break down.
it makes more sense to say that because the synthetic oil has a smaller particle, it's easier to slip through areas that a large particle oil wouldn't.
I ran synthetic in my car for 2 years, and never once developed a leak. many people run it too. I just recently switched to non-synthetic for one change just to see if it brought my oil pressure up a bit.
Kyle
Old 04-15-2008, 08:05 AM
I would agree with that comment about synthetic oils...Synthetic oil is not hard on seals, in addition the seals on older cars....say 20 years, would have never been built to use synthetic oils, so the would be more likely to leak. If you put synthetic oil in a old 911 say early 70's, late 60's I would think it would leak.
Old 04-15-2008, 08:55 AM
I think synthetic causes leaks because it dissolves sludge that is coating old hardened and cracked seals or gaskets. Once sludge is gone seal is more prone to leak. if engine is fairly clean synthetic is less likely to cause leaks.
Caution: Seafoam is know to dissolve spit, elmers glue and duct tape, and loss of oil pressure is possible. It will not harm metal items such as bailing wire, however.
Old 04-15-2008, 04:38 PM
earlr85944's Avatar
I gree w/ dj on the synthetic deal, safe to use on new to clean stuff but w the older stuff leaky seals are possible
83 944....bye bye
Old 04-15-2008, 04:42 PM
