xupkid2's Avatar
Vaccum Lines - Not The Typical ?
I've been through the posts regarding the vaccum lines and haven't found an answer. I've looked at the diagrams and can't find an answer so I'm going to ask.
I have an 88 944 NA. I have removed the AC because it is a full race car. I am having a problem with my brake feeling a bit spongy and am thinking it might be the vaccum to the brake booster. I see from the diagram that the line from the booster goes to the ejection pump. Since I don't have AC and the AC lines that connected to the ejector pump are gone am I missing out on the vaccum? I just have some paper towl stuffed in there to keep dirt out.
On my other 944 the vaccum line from the booster has a Y on it and one end goes to the ejection pump and the other to a canister near the battery. I have also removed the canister so I have a line that goes directly to the ejection pump. Could it also be that I need the canister to get the right vaccum? The motor runs fine but the braking is a concern. Let me know your thoughts.
Brian
1989 944 Turbo Cup Replica
PCA Space Coast Region #44
Old 04-15-2008, 01:36 PM
Lack of vacuum to the booster would make the pedal stiff, not spongy.
A spongy feeling brake pedal would make me thing you either have air in the lines, or even a bad seal in the master cylinder. My suggestion would be to bleed the brakes.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 04-15-2008, 03:15 PM
xupkid2's Avatar
Sorry I forgot to say I've blead the brakes and have a clear stream with no bubbles. I was thinking it was the master cylinder also but wasnt sure. I dont want to replace parts if I dont have to.
Brian
Old 04-15-2008, 03:17 PM
A cocked pad could make for a spongy pedal, so too could a bad master.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 04-15-2008, 03:27 PM
Quality
phoenix_iii's Avatar
Bleed the brakes with a vacuum bleeder (or power bleeder). Significant difference, epsecially if the car is not perfectly level while bleeding.
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 04-16-2008, 07:42 AM
xupkid2's Avatar
Thanks for the suggestion however a power bleeder is how I blead the brakes. I've ordered a booster and master cylinder so Im going to give that a try. Hopefully they will firm up. I run race pads in them so once I get them warmed up they seem ok but until then they are terribly soft
Old 04-16-2008, 08:07 AM
