Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Help my memory.....fr rotors?
Early rotors....do the bearing races need pressed in? Cannot remember....iirc they will compress when the axle nut is tightened. Thanks
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 04-16-2008, 06:43 AM
924RACR's Avatar
Not exactly; the bearings press into the hubs, not the rotors, the rotors are bolted to the hub. What do you need to do, replace the wheel bearings or the rotors?
Either way - no, you cannot draw the bearing races into place by tightening the spindle nut.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 04-16-2008, 06:52 AM
924Sman's Avatar
There was my error. I was visualizing incorrectly. I kept visualizing the rotor and hub as one. thanks Vaughan!
Dal
Old 04-16-2008, 08:32 AM
924RACR's Avatar
N E time!
Vaughan Scott
http://www.924.org
Old 04-16-2008, 10:09 AM
