I updated the first post with my latest diagnosis.
It would be better if you just added another entry to where your at. That way we can follow the history.
How do you know the DME is good? Who rebuilt it? What was bad with it? My issue was a bad dme. Replaced it with a known good one and I was good to go, then I sold the car. |
When then engine is not cranking, this should be 12V. When it is cranking the DME should pulse this to ground. If this wire is permanently at 0.5V, it's a problem. The Coil could be bad, or look for a short to ground on this wire (Remove the DME so it doesn't get spiked while fault finding). Cheers |
Ignition switch? Cheap and cheerful.
But I don't believe this is your problem. The 12V to the coil passes through this switch, not the coil signal. You have the 12V at your coil, so it's probably OK. Change it out if you want (it won't hurt), but hunt for the short on the green wire. Cheers, Jeff |
Diagnosing no spark conditions are tedious and maddening. I feel your pain. You just gotta be methodical and stick with it and eventually you'll figure it out.
You replaced both sensors - did you move the sensor bracket at all? Is there a chance they're gapped wrong? That'd do it. |
I took the DME to a company to have it checked. They replaced the A/D converter, which processes the Ref & Speed signals. Quote:
If you chk the coil, both terminals will show 12V due to continuity between the internal coils during cranking. This signal wire is part of the problem, may point to a faulty DME. Or a short. Next I will check the signal using an oscilloscope, just to see if it is flat, or if I really have some type of pulsed signal. Also contacted the company that rebuilt my DME, told me to chk for injector pulse. I will chk this to confirm if that circuit of the DME is working, but I am concerned more with Spark right now. |
Removing the green wire and checking for a pulse will not give you a conclusive result. The Darlington driver (transistor) in the DME, that outputs the pulse signal requires the 12V from the coil to be in circuit for it to work. Good idea to get an oscilloscope to look for the signal with the green wire connected to the coil. A quick and nasty way to see if you may have a signal is to check it with a DVM across the coil. The pulses will be too quick for the meter to measure, but the meter should average the measurement or flicker slightly lower than 12V. If you can easily get an oscilloscope then it is the better option. You can use a Noid light to check the injector pulses, but if you don't have any tach bounce then you won't have any injector pulses either. You may still have issues with your speed sensor. while you have the o-scope, check the speed signal at the DME plug. Cheers |
The car now runs great.
Summary of what I did recently AFTER confirming the ignition switch works, the DME/engine wiring harness is ok, and the coil works. I checked the output for my new ref and speed sensors at the harness using an oscilloscope. The pictures are linked below for everyone's reference, the output was strong. I checked for coil pulse and had none. I checked for injector pulse and had none. I checked for tach bounce and had none. My DME harness was getting 12 volts, and had good grounds. So basically my DME inputs were great, and I had no outputs at all. Contacted the ECU specialist and had them check the DME again, and it was fried. They gave me a replacement, and the car started. So overall I have replaced the original ref and speed sensor. I also replaced the DME relay. Had the DME rebuilt. (Company was great to work with, took the unit back and gave me another working one. They have a 5 yr warranty on their work, it came in handy.) http://img137.imageshack.us/img137/9...0904081bz0.png http://img137.imageshack.us/img137/6...0904081ul8.jpg |
Thanks to everyone that posted and to the forum for all your help.
I am very happy to have the car running, now I can enjoy it a bit before I start work on my steering issue, and sloppy shifter. |
Congrats on getting it going!
Get a good used DME and use it for troubleshootingt in case you have a no start, saves alot of headaches. |
Resurrecting an old thread here. We had an intermittent stall/no start issue with our '86 951 that we traced to the speed ref sensor, right near the plug. The wires were cracked and frayed. If you wiggled it, you could get it to start. If it was running and you wiggled it, you could get it to stall. So, I bought the reference sensor replacement harness (for both sensors). The sensors had already been replaced. I installed this per the instructions and now, no start. No tach bounce either. I went back and verified all the connections. Everything is correct. I verified continuity from the sensor plugs to the DME pins. All good.
The car ran great before the harness install. tI started it a couple hours ago to move it to a different staall in the garage. Started, ran fine, then I shut it off by wiggling the speed sensor wire. This would seem to confirm for me that all other sytems should be OK. I have to believe that it is related to the wiring of the two reference sensors, but I can't imagine what it is. And essentially everything electrical that could be replaced on this car, has been replaced or rebuilt over the last couple of years (DME, all sensors, AFM, relays, wires, coil, fuel pump, etc., etc,). Baffling. Roger |
Check and clean grounds. The battery ground on bell house and the sensor ground on engine crank case. Those made my S not give a spark.
Does your car have factory alarm? If so, try to bypass it if it doesn't have the 928 part number. See Clark's Garage. This made my S not give spark as well. Good luck. Note: I see that you did get it running, after I posted. Still stand by my two check points. |
When you say "verified connections" you mean that you verified that the sensors were connected to the correct plugs, right? I know you did, but for the conversations sake or anyone reading who doesnt know, the symptoms shown here can be caused by the sensors being swapped- the sensors are indentical in form but not function.
Roger |
No alarm. Roger |
So correct me if I am wrong in my thinking. I can use 2 identical reference or speed sensors and install them(1 as a reference/1 as a speed sensor in their respective location in the reference/speed sensor bracket), and the DME would use these identical reference or speed sensors accordingly to their respective plugged in connection to the DME harness? Or like you mentioned, the form might be the same, but they are totally different functioning products. |
Roger |
I didn't read the whole thread but double check the sensor gap, I had an intermittent no start when it was off a hair
| All times are GMT -8. The time now is 01:17 PM. |
