-   -   No spark, No tach bounce, 2 new sensors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/407268-no-spark-no-tach-bounce-2-new-sensors.html)
Big40ozs 05-02-2008 08:10 PM
No spark, No tach bounce, 2 new sensors: FIXED.
Status: Just bought an 88 N/A. Cranks but won't start.
Jumped the DME relay. I can hear the fuel pump.
Installed new Ref and Speed sensors.
Coil chk OK.
I STILL have no spark, and no tach bounce.
Tomorrow will chk continuity between sensors and DME.
Any other ideas? Am I forgetting anything obvious?
mikepellegrini 05-02-2008 09:37 PM
Have you read through the troubleshooting section at Clarks? I've always found it really helpful: http://www.clarks-garage.com/shop-manual/ts-01.htm and for ignition problems: http://www.clarks-garage.com/shop-manual/ign-04.htm
Are you sure the sensors are gapped properly? How's fuel pressure?
How about the connections between the DME and the sensors? (this plagued us forever on my kid's 86 951. Took months to figure out. Had to replace the harness).
Where have you checked for spark? At a plug wire or the wire from the coil? (you're sure it's not a dirty distributor cap or rotor?).
You have a known good DME you can use?
One time my kid replaced his coil with a new MSG coil and a couple days later, the car crapped out. We screwed with it and screwed with it - what it was was a defective NEW coil. It checked out okay in the tests, but it just couldn't produce a good spark. Replaced it with the old coil and the car ran great.
Lots of luck. Problems like this drive you nuts! Just hang in there....
kdjones2000 05-02-2008 11:25 PM
Sounds like a DME to me....
I would check Clark's to see if there are other suggestions.
Keith
Big40ozs 05-03-2008 05:41 AM
mikepellegrini,
Which harness did you replace?
Are you talking about the harness side sensor connectors or the wiring itself?
mikepellegrini 05-03-2008 06:42 AM
We replaced about a one foot section of the harness between the speed and refrence sensor plugs and the DME.
The problem was the plugs themselves - or rather the wiring immediately leading into the plugs (on the DME side).
Apparently, the plugs had been handled too much and the wires leading into the plugs had broken (not all the way but it was enough so they didn't have a steady connection). The way we finally diagnosed this was by having someone jiggle the wires while another person cranked the car over. If you jiggled the wires just right, the car would usually start.
We tried soldering the wires back into the plugs and that really didn't work. So we got the harness from another car, and spliced in the one foot section leading to the plugs (both speed and reference sensor plugs) and now it works good. No more starting problems.
I should say he did have another problem that appears to have resolved itself: there was either a problem with the connector at the DME, or maybe the DME itself - if you stomped on the floorboards by where the DME is, the car would cut out. Or sometimes, if you even slammed the door.
The DME connector was securely plugged in, so that wasn't it. But like I said, this resolved itself - hasn't happened again in months.
In my son's case, I'm thinking his whole engine wiring harness is possibly semi-toast and that the way to once and forever fix the problem is to completely replace the harness. If the problems start again, that's maybe what we'll do.
Try jiggling the wires and see what happens.
Another thing to check are your grounds - bad grounds can cause a whole lot of problems like this. We had an 84 NA that had problems with that. After we located and cleaned everything, it finally started good every time.
mattdavis11 05-03-2008 07:56 AM
I had the same problem after I replaced the positive terminal connector. The single lead for the dme (I gather) was not making good enough of a connection. I thought it should have been good, it was bunched in the connector clamp as good as the other wires were. Stripped the wire back some, cleaned it up, good to go.
Big40ozs 05-17-2008 08:03 AM
Update: No spark, No tach bounce
DME:
DME checked out bad. Had it rebuilt. Still no start, no tach bounce, no spark.
Ref and Speed:
Did a continuity check from DME connector to sensors.
Wires/connectors are ok.
Used oscilloscope to check ref and speed signals at the DME connector.
Signals are strong.
DME connector grounds and 12v+ are fine.
COIL:
Wanted to check coil by itself using Clark's Garage method.
Primary and secondary resistance is within spec. So on to "spark check".
BUT......I cannot get a spark out of it. The ground wire that I am "tapping" to batt. gnd is sparking instead.
So I tried with an aftermarket and same thing.
Its almost as if they are shorting when I tap to ground.
Why does the resistance check out OK, but the thing won't spark?
Do I need to hold it to gnd longer to charge it? Or is something else the issue?
I know this is not the only problem, but I at least want to eliminate this variable.
________________________________________
Update:
9/1/08
The coil is fine. I checked it outside of the car and it generates spark.
The way I did this was by using a 9 volt battery.
It would not work with 12V. This must be an ignition that has a resistor internally. eg. within the DME.
onZedge 05-17-2008 10:57 AM
Two coils with the same problem is unlikely. Turn on the ignition switch. You should you have voltage at the small coil wires - both of them.
Big40ozs 05-17-2008 01:18 PM
I have 12v at both of the primary leads of the coil.
I'm just not sure why it checks out ok electrically (primary and secondary resistances in spec), but it won't generate spark when I ground the neg terminal.
KY944S 05-17-2008 03:38 PM
If you have a factory alarm you may want to try and buypassing it. This is also found in clarks.
onZedge 05-21-2008 03:59 PM
Originally Posted by Big40ozs (Post 3921230)
...Just bought an 88 N/A...Am I forgetting anything obvious?...
If you are using the engine to ground the spark plug for the spark test - and you can't get a spark with two different coils, you have to ask yourself "Hmm, I wonder if the engine block is actually grounded"
jmd_forest 05-21-2008 04:28 PM
Check to make sure the timing belt is not broken. Broken timing belt = stationary cam, stationary cam = stationary rotor = no spark at spark plugs.
Also, as KY944S states, try bypassing the alarm. It will eliminate that variable.
If possible, transplant your DME into a known running 944 to verify your DME is good.
jmd_forest
hpservertech 07-18-2008 08:50 PM
Did you ever solve this? I'm having the exact same problem!
Spidey944 07-19-2008 02:50 PM
I did this on my car, well, went through it anyway about a year ago. Turns out the bolt holding the distrubuter rotor on fell out and the engine would catch once in a while but never start. Took me 3 days to find the issue, and i'm an ASE cert. mechanic for 10 years! Just a thought. I felt so stupid, because i pulled the cap off and saw the one bolt, but forgot that there are two bolts holding everything together.
onZedge 07-19-2008 03:52 PM
After re-reading this thread, I don't see where the injector wires were checked. With the ignition on, there should be battery voltage (or close to it) at both.
hpservertech 07-19-2008 04:12 PM
Ok. You got me thinking. Made sure that the rotor was at least turning, so at least the belts aren't broke.
I did take the distributor off as well as the rotor. Should I be able to get continuity between the middle of the rotor to the end of the rotor? Also, shouldn't I be able to get continuity on the distributor on the outside pins to the inside? This isn't making any sense to me.
onZedge 07-19-2008 04:17 PM
You should have close to zero ohms between the inside of the dist cap and its corresponding pin on the outside. I have to check about the rotor. I will edit this post when I measure a spare (gimme a minute)
EDIT: WRONG! I read 1-1.5K ohms across the dist cap terminal pins and 1K ohms across the center tower. I read 1.5K ohms across the rotor. Both caps were used, one Bosch, one Beru. Rotor was used Bosch.
hpservertech 07-19-2008 06:03 PM
Well I have followed Clarks page for the ignition coil. http://www.clarks-garage.com/shop-manual/ign-04.htm
Everything checkes out ok, except from getting spark directly from the oil. So if I read it correctly the coil is bad. Going to see if i can borrow someones coil & dme tonight and at least get it started.
Outback Porsche 07-20-2008 06:00 AM
I'm assuming that you have no tach bounce, as the thread title states.
This would mean that you have no switching ground signal (or pulsing ground) leaving pin 1 of the DME. This is signal that 'drives' the coil and is split at the 9 pin connector on the firewall of the engine bay (pin 1 or the heavy green wire) and goes to the tacho.
One of two things is happening;
a) At the coil you have 12V on both primary terminals and no evidence of a pulsed ground from the DME. The fault exists from the DME back, and could include the speed sensor.
or b) You have 12V permanently across the primary of the coil. which would indicate that the output of the DME is being shorted to ground somewhere. Alarm system, DME, wiring, etc..
Cheers,
Outback Porsche 07-20-2008 06:41 AM
If you want to check your coil, could could try this;
This is the disclaimer part. There is some risk here of being electrocuted by the back EMF (Electro Magnetic Force) of the coil. Care need to be taken (But it does make a funny story to tell your mates if you do electrocute yourself and any spectators will get a good laugh). Insulated pliers will help.
Rotate the engine so that you have electrical continuity through the rotor to a spark plug and remove the spark plug. Disconnect the wire on the coil from the DME (the green one). Whilst grounding the spark plug to the engine, tap the DME terminal on the coil with a flying lead that you have connected to ground. You should see a strong spark on the plug.
Cheers,
Outback Porsche 07-20-2008 06:45 AM
Cheers,
Forgot to mention, turn the ignition on.
Big40ozs 09-01-2008 09:17 AM
I updated the first post with my latest diagnosis.
hpservertech 09-01-2008 09:27 AM
It would be better if you just added another entry to where your at. That way we can follow the history.
How do you know the DME is good? Who rebuilt it? What was bad with it?
My issue was a bad dme. Replaced it with a known good one and I was good to go, then I sold the car.
Outback Porsche 09-01-2008 04:04 PM
Used volt meter and found green coil signal wire has ONLY 0.5 volts. (This is supposed to be near 12v right?)
Follow this up. This sound like the key to unlocking your mystery.
When then engine is not cranking, this should be 12V. When it is cranking the DME should pulse this to ground. If this wire is permanently at 0.5V, it's a problem.
The Coil could be bad, or
look for a short to ground on this wire (Remove the DME so it doesn't get spiked while fault finding).
Cheers
Slam 09-01-2008 05:00 PM
Ignition switch? Cheap and cheerful.
Outback Porsche 09-01-2008 06:25 PM
Not a bad idea if it hasn't been changed recently. They are cheap and they fail often. A lot of current passes through this switch when you start up. I recommend changing this ever couple of years. Probably a good thing schedule with the belts.
But I don't believe this is your problem. The 12V to the coil passes through this switch, not the coil signal. You have the 12V at your coil, so it's probably OK. Change it out if you want (it won't hurt), but hunt for the short on the green wire.
Cheers,
Jeff
mikepellegrini 09-01-2008 08:50 PM
Diagnosing no spark conditions are tedious and maddening. I feel your pain. You just gotta be methodical and stick with it and eventually you'll figure it out.
You replaced both sensors - did you move the sensor bracket at all? Is there a chance they're gapped wrong? That'd do it.
Big40ozs 09-02-2008 01:20 PM
I'll add my updates to new entries, thx for the tip.
I took the DME to a company to have it checked.
They replaced the A/D converter, which processes the Ref & Speed signals.
Cheers
Just to clarify, I disconnected the green wire and checked it with a voltmeter to ground with someone cranking the car. It was showing 0.5 volts.
If you chk the coil, both terminals will show 12V due to continuity between the internal coils during cranking.
This signal wire is part of the problem, may point to a faulty DME. Or a short.
Next I will check the signal using an oscilloscope, just to see if it is flat, or if I really have some type of pulsed signal.
Also contacted the company that rebuilt my DME, told me to chk for injector pulse.
I will chk this to confirm if that circuit of the DME is working, but I am concerned more with Spark right now.
Outback Porsche 09-02-2008 03:28 PM
Sorry, I misunderstood that you had 0.5V with the coil in circuit.
Removing the green wire and checking for a pulse will not give you a conclusive result. The Darlington driver (transistor) in the DME, that outputs the pulse signal requires the 12V from the coil to be in circuit for it to work.
Good idea to get an oscilloscope to look for the signal with the green wire connected to the coil. A quick and nasty way to see if you may have a signal is to check it with a DVM across the coil. The pulses will be too quick for the meter to measure, but the meter should average the measurement or flicker slightly lower than 12V. If you can easily get an oscilloscope then it is the better option.
You can use a Noid light to check the injector pulses, but if you don't have any tach bounce then you won't have any injector pulses either.
You may still have issues with your speed sensor. while you have the o-scope, check the speed signal at the DME plug.
Cheers
Big40ozs 09-22-2008 08:13 AM
The car now runs great.
Summary of what I did recently AFTER confirming the ignition switch works, the DME/engine wiring harness is ok, and the coil works.
I checked the output for my new ref and speed sensors at the harness using an oscilloscope.
The pictures are linked below for everyone's reference, the output was strong.
I checked for coil pulse and had none.
I checked for injector pulse and had none.
I checked for tach bounce and had none.
My DME harness was getting 12 volts, and had good grounds.
So basically my DME inputs were great, and I had no outputs at all.
Contacted the ECU specialist and had them check the DME again, and it was fried. They gave me a replacement, and the car started.
So overall I have replaced the original ref and speed sensor.
I also replaced the DME relay.
Had the DME rebuilt. (Company was great to work with, took the unit back and gave me another working one. They have a 5 yr warranty on their work, it came in handy.)
http://img137.imageshack.us/img137/9...0904081bz0.png
http://img137.imageshack.us/img137/6...0904081ul8.jpg
Big40ozs 09-22-2008 08:20 AM
Thanks to everyone that posted and to the forum for all your help.
I am very happy to have the car running, now I can enjoy it a bit before I start work on my steering issue, and sloppy shifter.
earlr85944 09-22-2008 06:47 PM
Congrats on getting it going!
Get a good used DME and use it for troubleshootingt in case you have a no start, saves alot of headaches.
Roger 911 05-16-2015 03:24 PM
Resurrecting an old thread here. We had an intermittent stall/no start issue with our '86 951 that we traced to the speed ref sensor, right near the plug. The wires were cracked and frayed. If you wiggled it, you could get it to start. If it was running and you wiggled it, you could get it to stall. So, I bought the reference sensor replacement harness (for both sensors). The sensors had already been replaced. I installed this per the instructions and now, no start. No tach bounce either. I went back and verified all the connections. Everything is correct. I verified continuity from the sensor plugs to the DME pins. All good.
The car ran great before the harness install. tI started it a couple hours ago to move it to a different staall in the garage. Started, ran fine, then I shut it off by wiggling the speed sensor wire. This would seem to confirm for me that all other sytems should be OK. I have to believe that it is related to the wiring of the two reference sensors, but I can't imagine what it is. And essentially everything electrical that could be replaced on this car, has been replaced or rebuilt over the last couple of years (DME, all sensors, AFM, relays, wires, coil, fuel pump, etc., etc,). Baffling.
Roger
mhariush 05-16-2015 04:52 PM
Check and clean grounds. The battery ground on bell house and the sensor ground on engine crank case. Those made my S not give a spark.
Does your car have factory alarm? If so, try to bypass it if it doesn't have the 928 part number. See Clark's Garage. This made my S not give spark as well.
Good luck.
Note: I see that you did get it running, after I posted. Still stand by my two check points.
Bradical 05-16-2015 05:23 PM
When you say "verified connections" you mean that you verified that the sensors were connected to the correct plugs, right? I know you did, but for the conversations sake or anyone reading who doesnt know, the symptoms shown here can be caused by the sensors being swapped- the sensors are indentical in form but not function.
Roger 911 05-16-2015 07:08 PM
Yes. I verified not only that the sensors were plugged in to the right plug, but verified that each wire was in it's correct place from the plug down to the DME. I did this to make sure that the new wiring harness wasn't mislabeled.
Roger
Roger 911 05-16-2015 07:16 PM
Good luck.
I know grounds are a common problem, but it was running a couple hours earlier, with only the aforementioned frayed reference sensor wire as an issue. It seems odd that replacing the sensor wires would trigger a ground issue.
No alarm.
Roger
fiily 05-16-2015 07:25 PM
Sorry about the Thread-jacking
So correct me if I am wrong in my thinking. I can use 2 identical reference or speed sensors and install them(1 as a reference/1 as a speed sensor in their respective location in the reference/speed sensor bracket), and the DME would use these identical reference or speed sensors accordingly to their respective plugged in connection to the DME harness?
Or like you mentioned, the form might be the same, but they are totally different functioning products.
Roger 911 05-17-2015 05:38 AM
Yes, the sensors are the same part #. They perform different functions. Obviously, if the wrong plug is attached to a sensor (speed to position, or position to speed), it won't work.
Roger
earlr85944 05-17-2015 06:56 AM
I didn't read the whole thread but double check the sensor gap, I had an intermittent no start when it was off a hair
