-   -   Reverse Light Sensor (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/407750-reverse-light-sensor.html)
lyons8821 05-05-2008 05:56 PM
My reverse lights do not work, where is the sensor at for the reverse lights?
thanks guys.
Joe
Arizona_928 05-05-2008 06:13 PM
are the bolbs burnt out?
944 Ecology 05-05-2008 06:50 PM
switch is on the transaxle... look for two wires going to the sensor.
If you have a 924S or an early 944 with the speedo cable in the left front wheel, it is the only electrical connection in the transaxle, otherwise, it is the one that is not the speedometer sender.
mattdavis11 05-05-2008 07:09 PM
As Ecology said for the earlies, it's on the passengers side. Jump the switch to see if they work first. My switch is inoperable at the moment, but I don't spend alot of time in reverse either. One day I'll have to inspect this thing, and buy a new switch, just waiting on the man to make me. Got a warning a year ago, didn't do much good.:D
lyons8821 05-11-2008 04:12 PM
Thanks guys I'll get to it. I just got a warning also. I will let you know what comes of it
