Angry another question.
Once again I have a 90 944 S2 with a intermittent starting issue. After almost ruining my car trying to bypass the alarm, I fixed a burnt wire removed the jumpers. I plugged the alarm back up and the car started right up about 15 times in a row. I let the car set 1 minute to 2 minutes before each start. Then it went back to it's old tricks. The engine will just spin...But for some reason you can open the door the shut the door never getting out and the car will start right up???????????????? It has been doing this along time(since I've had the car). When the car doesn't start open the door the close it and it will start right up. It has to do with the alarm has to.? But what am I missing? Also there is a long thin black electronic box under the carpet in the trunk, What is that? I want to sell this car but it is eating me alive trying to figure out the no start issue.
1990 944S2 cab
1987 944 n/a
08 Mazdaspeed3
1998 Dodge Ram
1988 Dodge Ram
Old 05-11-2008, 04:21 PM
Arizona_928's Avatar
sounds like fuel pump relay might not be in all the way.
so also check for loose wires, replays, and fuses....
dolor et pavor
Copyright
Old 05-11-2008, 04:31 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Long box under the carpet in the trunk.....Maybe a radio amp?
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 05-11-2008, 05:23 PM
I have lifted the fuse box out of the car looking at that already. I have checked every thing I can think of the DME relay is new also. Could this be from a faulty ignition switch? What are some symptoms of a bad ignition swictch? Im just taking wild guesses.
1990 944S2 cab
1987 944 n/a
08 Mazdaspeed3
1998 Dodge Ram
1988 Dodge Ram
Old 05-11-2008, 07:46 PM
idk about the dme but if it's cranking and not even a huff comes out, it's most likey fuel related. you can see if the fuel pump is getting any juice by cranking it and measure the volts. and if it isn't getting anything, follow the wire. it's most likely a loose wire along the way somewhere.
also a quick test to see if it's fuel, is carb cleaner in the throttle bod. and it it starts up it's fuel related
dolor et pavor
Copyright
Old 05-11-2008, 08:04 PM
