ref. sensors
hi all ,
having a start prob with my 89 s2 it cranks and cranks and cranks then splutters into life ,runs perfect other than this . while snooping around last nite i discovered that i only have 1 sensor on top of the bell housing the 1 nearest the fire wall is missing !!!!! p.o or some 1 removed it maybe why?? would this have something 2 do with the starting issue tks for any input much appreciatedSmileWavy |
S'es and S2's I have found out only use a single reference sensor; they get the reference signal from a missing tooth on the flywheel.
I would check your fuel pressure regulators; I had a hard start problem when those started dying on me. Good luck, Keith |
well thank god for that , 1 sensor only .
spark plugs and leads brand new , going to get a new f.p.r and take it from there it seems to be the most popular reply. tks for the input guys always appreciated !SmileWavy |
| All times are GMT -8. The time now is 06:14 AM. |
