rob c
comicbook8@gmai's Avatar
Porsche Crest ref. sensors
hi all ,
having a start prob with my 89 s2 it cranks and cranks and cranks then splutters into life ,runs perfect other than this . while snooping around last nite i discovered that i only have 1 sensor on top of the bell housing the 1 nearest the fire wall is missing !!!!! p.o or some 1 removed it maybe why??
would this have something 2 do with the starting issue
tks for any input much appreciated
Old 05-15-2008, 03:37 PM
In the Fires of Hell.....
kdjones2000's Avatar
S'es and S2's I have found out only use a single reference sensor; they get the reference signal from a missing tooth on the flywheel.
I would check your fuel pressure regulators; I had a hard start problem when those started dying on me.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-15-2008, 05:04 PM
70SWT's Avatar
Originally Posted by comicbook8@gmai View Post
hi all ,
If the fuel pressure checks out, how are the spark plugs?
2018 911 Carrera coupe
1972 911T targa
Old 05-16-2008, 04:19 AM
rob c
Porsche Crest
well thank god for that , 1 sensor only .
spark plugs and leads brand new , going to get a new f.p.r and take it from there it seems to be the most popular reply. tks for the input guys always appreciated !
Old 05-16-2008, 01:49 PM
