Park Brake Switch?
The switch under my park brake lever has come apart. I have the spring, a small thin cad plated washer & the 'switch' (black plastic sensor with an electical spade connector on the bottom) itself. I can see the slotted bracket that the bottom the spring rest on but I think I am missing some bits.
Can anyone show me an exploded parts diagram or photo of the unit properly assembled?
Spud
Old 05-25-2008, 05:01 PM
OK - so nobody has any pictures for me. Can anyone tell me how the switch goes together and how it is held in place?
Spud
Old 05-27-2008, 06:00 AM
Back from Beyond
It's just a spring-loaded momentary switch, I believe. Your best bet is probably to just find a good used one here on Pelican.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 05-27-2008, 10:02 AM
In the Fires of Hell.....
kdjones2000's Avatar
I just saw the whole arm thing on Ebay recently....
Here you go: http://cgi.ebay.com/PORSCHE-944-951-TURBO-BRAKE-PARKING-BRAKE-HANDLE-SWITCH_W0QQitemZ110256286151QQihZ001QQcategoryZ335 55QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-27-2008, 12:17 PM
Just to close the loop - I figured out the solution to my problem. I removed the switch bracket, switch & spring. I learned that the bracket was bent out of shape. I straightened the bracket and correctly set the spring and switch. The way the switch works is as follows. When the park brake is released the switch is pushed up by the spring until the electrical contact at the bottom of the switch makes contact with the bracket. This ground the switch and turn the light on. When you put the park lever down the switch is depressed and no longer makes contact. My switch was not working because the bracket was bent out of shape. All it took was a simple straightening and every thing works fine.
Spud
Old 05-29-2008, 03:08 PM
Semper drive!
rcecale's Avatar
bjaspud, you didn't, by chance, happen to take a pic of your switch when you got it re-assembled, did you? Mine seems to have come apart just like yours did.
Didn't see a washer, but I can certainly have another look. I did, however, manage to retrieve these three parts...the plunger, the spring and the bracket (sorry for the blurry phone-pic).
Our host sells these for about $15.00, but if I can get this one put back together, that would be cool too.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 11-06-2008, 08:52 AM
Send a message via ICQ to bud9344 Send a message via AIM to bud9344
Parking Brake Switch
Here is some pictures from and 86 951 and 83 944
I have done this every time I got the car, every one of them the Parking brakes switch fall apart
86 951 fix it when I got the car
83 944
Put the spring on the black shaft and install it on the bottom part off the housing and compress the spring push the top black shaft to the top ana make sure the holder have 90 degree on both end
Good Luck
Bud
Old 11-06-2008, 11:53 AM
rcecale ther is a ring misiing on yours from you picture, after taking a good look at your picture. some part off the plastic is broken. that is why the metal piece is expose to much
I think you better off getting a new one Sorry
Bud
Old 11-06-2008, 12:48 PM
Semper drive!
rcecale's Avatar
Thanks for the great pics, bud! Helps a lot.
Yeah, I knew there was a little washer missing, and honestly, for the price of a new switch, it's probably easier to just buy it than to track down the specific washer I need. Especially given the broken plastic bits.
time for another order from our most gracious host!
Cheers!
Randy
One Marine's View
Old 11-07-2008, 08:10 AM
