Mountain Road Maniac
ColoradoSteve's Avatar
Stupid AC question.......
I am attempting to recharge my AC system with one of the kits but I'm not sure I'm using the right port to put in the R134a . It's the port right in front of the reservoir with the sight glass on top? The only other ports I can find are located on top of the compressor ... not easy to get to! Using this port I can get very little ( half a can) 134a in there before the pressure goes to 45-50 psi but I get a stream of bubbles in the sight glass which means the refrigerant is low? Anybody got a clue?
Old 06-02-2008, 09:40 AM
aj951's Avatar
I am pretty sure that the port you are using is the high side port (if it is located on the same line as the dryer with the site glass) and the port near the compressor is the low side port. You should be using the low side port to put the refrigerant charge in your system. Also when charging a system designed for R12 with R134A, you use less refrigerant than the system was designed for and you will have bubbles in the sight glass even though the charge is correct.
A.J.
89 944 Turbo
Guru Chip
Lindsey Boost Enhancer
3bar Reg.
Old 06-02-2008, 10:01 AM
Just thinking out loud
mattdavis11's Avatar
The low side is on the compressor, and it's a bytch to charge. Charging on the high side can work, but you might lose a hand. It's a pain in the ass. Shorten the belt? And 83%, works for me.
91 FJ80
84 Ram Charger (now gone)
Old 06-02-2008, 10:40 AM
Well, shucks, I knew this couldn't be that easy. Thanks for the info, guys
Old 06-02-2008, 01:59 PM
tnporsche's Avatar
I used freeze 12 and it only took, the oil charge (it has 2 oz F12) and one half 8 oz can of F12. I too have bubbles but it cools great . I tried to do it without a set of gauges using just the low side hose and blew the seals in the pump. BAD JUJ JUJ LOL
Now I swear I'll never charge again without knowing what the high side is, and use the temp chart!
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 06-02-2008, 03:00 PM
Well I guess I'm going to have 2-60 ( maybe 2-80) air this summer cause there's no way to get the 134a adapter on the low side port. Even if I could get the adapter on, the connector to the refrigerant couldn't fit in the small space. There must be a different adapter setup for doing this ???!!!
Old 06-02-2008, 04:29 PM
A 1 inch shorter belt and a 90 degree 134 fitting works best. Napa has the belt, or they did. NBH25050390.
Yep, they still have it. http://www.napaonline.com/NOLPPSE/(S(dt2h2nyadldw4555vdollvqa))/Detail.aspx?R=NBH25050390_0117502550
91 FJ80
Old 06-02-2008, 06:17 PM
Thanks, Matt... I'll get the belt and give it a try. I don't really need the air but I just want to get everything working...I'm sure you understand LOL!
Old 06-02-2008, 06:42 PM
