thoen's Avatar
Short Block or Long???????
I have a 1983 944. How do I know if it is a short block or not? what is the difference between the two blocks?
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 06-04-2008, 05:31 PM
unindicted co-conspirator
looneybin's Avatar
The only difference i've ever heard of is a short block only has the crank shaft & pistons installed & a long block also has the heads & valve train installed.
I don't think that there is any difference in the motors, except i think the '88 has higher compression
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 06-04-2008, 05:55 PM
+1 Overheard in a parts store: "Oh, I'd better get the short block. I don't think I'd be able to fit a long in there!". Just another confusing term that refers to buying a rebuild and what's included. Not to be confused with "big block" in reference to American muscle cars.
Old 06-04-2008, 06:12 PM
Redline Racer
HondaDustR's Avatar
The salesman at the store should have said "You better get the short block. You'll save on weight and the handling would be better!"
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 06-04-2008, 07:59 PM
thoen's Avatar
the question is....How can I tell what I've got? The block looks Normal sized....what makes it a short block and what makes it a large block. What would I look for that would tell me one way or the other??
Old 06-05-2008, 01:18 PM
The point is.. the block is the block. "Long" or "tall" bears no relationship. If you have no head on it then it's "short".
Old 06-05-2008, 02:44 PM
rmcdonnell's Avatar
What's the difference?
ANS: The cylinder head ( which = a long block - a short block)
cheers
Russell
944 Alpine White '89 2.7L
Old 06-05-2008, 02:55 PM
Short Block = 1/2 engine
Long Block = whole engine
If your engine is in the car and it runs, you've got a long block. Now turn the car off and remove the head, and fuel injection and you now have a short block (it's short a few parts). Same engine can be both
Has nothing to do with size.
Old 06-05-2008, 03:24 PM
thoen's Avatar
I am now enlightened!!!!
I had no idea of the meaning of the short/long block. NOW I know,
thanks.
Old 06-05-2008, 03:32 PM
Redline Racer
HondaDustR's Avatar
As far as I know, every bit of electric, plastic, accessories, fuel system, ignition system, intake, exhaust, the works is not included with a short block. You just get the block, crank, rods, and pistons. You may not even get an oil pan. Pretty much every part that can be removed from those few main components does not come on a short block.
They sell it as a cheaper option if you are rebuilding and want to start fresh with the critical engine parts and reuse all the stuff that either doesn't really go bad, is functioning fine already, or would be cheaper and/or easier to rebuild than to replace.
Old 06-05-2008, 04:11 PM
