Quality
phoenix_iii's Avatar
How to ground the cluster - Where is the P-ground, or easy way to add another?
My cluster needs better electrical grounding. My oil pressure needle swings like a bad ground, and I just had the oil pressure sender replaced. My speedo needle bounces a little bit at slow speeds, and I've even seen my fuel needle twitch.
The grounds under the dash (on the floor, looking up) are good, I cleaned them anyway and they were pretty mint.
Where is the electrical for the gauges grounded, or where to where can I add a wire? Thank you so much! Car is coming along so great!
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 06-19-2008, 11:25 AM
Professional Bull5hiter
Outback Porsche's Avatar
Have you seen this;
http://www.pelicanparts.com/techarticles/944_taillight/944_gauge_problems.htm
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-19-2008, 04:58 PM
Quality
I have but was hoping I didn't need to pull the steering wheel/trim just to 'check' that. Is that my only/best course?
Old 06-20-2008, 04:01 AM
Custom User Title
Dave L's Avatar
man I love this site. My gas guage never goes past 3/4 and sometimes at idle the speedo needle will bounce a bit. I guess I will be pulling out my cluster too.
-> add one more project to the ol' 944 to do list.
Old 06-20-2008, 04:38 AM
Probably. I also remember reading something about adding an additional ground wire from the instruments to the dash frame can fix this. Either way you'll need to pull the instruments.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 06-20-2008, 06:01 AM
